Stock Shock/Strut Dimensions?
Old Feb 17, 2008 | 11:04 PM
HEMI-Fit's Avatar
Anyone have a resource for the dimensions of the OEM shocks and struts? Since there aren't many (any) choices for just plain old upgrade shocks and struts, I'm wanting to see what else out there comes close enough for government work. I was hoping to get out this weekend and at least measure the rear shocks, but the weather sucked.
So, what I'm looking for are these dimensions:
Rear Shocks -
Extended & Compressed length
End Treatments (loops or pins, stud sizes, etc.)
Struts -
Lower mount bolt sizes/locations
Shaft DIA
Spring perch DIA
...and whatever else you need to tell if one strut is the same as another.
If this info is in the FSM, I guess I need to get one of those on the way, but it seems like the kind of detail the dealer monkeys aren't really concerned with.
Thanks in advance for any help on this stuff, and I promise I'll post up my findings when the results start rolling in.
HF
Old Feb 20, 2008 | 05:37 PM
mahout's Avatar
Since I carry heavy loads in the back seat and trunk occasionally I found Monroe MaxAir shocks MA811's fit very nicely. Only washers are needed to make up for the Fit yoke being wider than the MA811 bushing. Works well on track too. For more info see the 'better rear design' postings.
Old Feb 20, 2008 | 11:42 PM
HEMI-Fit's Avatar
Thanks, mahout, I've been reading on that one, too. I'll actually try to pull one this weekend, if the weather doesn't go to pot again...
HF
phoenity
Feb 11, 2026 03:22 AM
shawnshank
Mar 30, 2018 05:34 PM
der Mond
Apr 7, 2016 02:54 PM
The Doge
May 27, 2011 12:11 PM
runbikerun
Aug 18, 2009 09:17 PM
