DIY - Mugen Short Shift Install
Old Mar 1, 2008 | 10:23 PM
  #41
raton's Avatar
thanks for the writeup raimondas! just installed mine today. like previously said, it feels more notchy and the throws pretty short. also, shifting feels just fine w/ my jdm center console.
install was pretty straight-forward....except...when i got to removing the metal shift cable clip. sucker felt stuck & wasnt budging. i couldnt pry it out w/ a flat-head. ended up using needle noze pliers...grabbed the center of the clip...and pulled (and pulled) upwards with hulk strength ...it finally came out. whew. everything else went smoothly.
Old Mar 2, 2008 | 12:16 AM
  #42
yeamans17's Avatar
I'd like to feel how it feels compared to my custom shifter that was in my accord. I just ordered mine from Panducky, and I ordered a bunch of stuff from A&J. So hopefully this month goes by quick
Old Mar 31, 2008 | 11:59 PM
  #43
SAWYER's Avatar
I just installed my Mugen shifter over the weekend. It feels alot better than stock. Its not a huge difference but definitely a noticable difference. It is alot more notchy and makes quicker, more secure shifts. shorter feels better also. overall good buy. very high quality.
Old Apr 4, 2008 | 12:17 AM
  #44
Chikubi's Avatar
I just installed mine today. Thanks for the DIY, it was very helpful. As for driving impression, the post above is spot on. It's very noticeably different, but the degree of difference isn't as much as one would expect. Still, much, much better than stock. In my case, I also installed mine using H-Fit's hard shifter mounts, so it's really solid feeling and decisive when you shift. A good combo for anyone thinking of getting this SS, I'd say.
Old Apr 9, 2008 | 11:03 PM
  #45
Fit Nutt's Avatar
Put mine in tonight. Great write up, helped out a lot. Took it out for a quick spin and felt a big improvement. Shorter, crisper shifts. Still not like the old school Honda linkage and rod shifters with a short shift kit, but better than stock.
Old Apr 11, 2008 | 01:45 PM
  #46
yeamans17's Avatar
I got my shifter in today, feels great. But due to poor communication I will never make a purchase from Panducky Motorsports again.
Old Apr 16, 2008 | 10:22 PM
  #47
its.ryu's Avatar
Im having trouble removing the black linkage on the left. I keep trying to turn it but it just wont turn. Anyone got any advices to removing it so I can get the last 12mm?
Old Apr 17, 2008 | 02:31 AM
  #48
Chikubi's Avatar
You've just got to be a bit more brave I suppose. It'll turn, but you really have to get your fingers in there to make it turn as it's a bit tight. It probably helps if you have smaller hands too to get more leverage. It'll go though, just keep trying.
Old Apr 17, 2008 | 02:36 AM
  #49
hondajazz2005's Avatar
raimond, i can't see some of the pics... can you fix that please?
cheers bro
Old Apr 17, 2008 | 09:20 PM
  #50
its.ryu's Avatar
Never mind I got it off. Now Im having trouble with another apart.
Old Apr 22, 2008 | 01:06 AM
  #51
i still dont know what is the different between mugen n skunk2 ...
Old Apr 22, 2008 | 02:58 AM
  #52
claymore's Avatar
The Mugen kit is a whole new replacement for the entire shifter mechanism. The Skunk 2 is just a small extension added onto the bottom of the stock shifter making the throws shorter. For the price the skunk 2 performs real well and if your worried about it coming off a couple of tack welds makes sure it will not come off unless you want it to.
Old Jul 9, 2008 | 02:52 PM
  #53
wdb's Avatar
wdb
First of all thanks very much for the thorough writeup and great pictures.
I'm shopping short shifters at the moment, and like so many other folks I'm flip-flopping between H-Fit and Mugen. I've been staring at the Mugen pictures and at the stock assembly you show in the install pictures, and for the life of me I can't see a difference between them as far as the large plastic housing is concerned. Is it possible that the Mugen kit is really just the stock parts with a different lever and firmer bushings?
Any assistance or side-by-side shots would be very useful. Thanks!
Old Jul 24, 2008 | 07:35 PM
  #54
ICIN235's Avatar
Where is the cheapest/best place to order the Mugen shifter from?
Old Aug 11, 2008 | 05:26 PM
  #55
trancedsailor's Avatar
I'd say go with kingmotorsports.com that's where I'm ordering mine and Mugen boots and skunk2 knob on September 1st come oooon first of the month lol
Old Aug 11, 2008 | 10:24 PM
  #56
FitVic's Avatar
This DIY made the install EASY!!! Thanks a lot for the DIY!!!
Old Sep 12, 2008 | 10:34 PM
  #57
kcharri's Avatar
This DIY helped out alot. The instruction sheet is basically useless, reprints info from the service manual. Check out evasive motorsports, I picked mine up for $209.
Old Dec 13, 2008 | 04:52 PM
  #58
jazzman's Avatar
Is the installation the same like skunk2?
I bought the skunk2 and i cant find any DIY
Old Jan 14, 2009 | 03:47 PM
  #59
eriko's Avatar
How Short ?
Hello All,
New here to the forum just was wondering how short is the throw on the mugen short shifter in inches! I have read that it is 20% shorter but how much is that in inches. Also is only the top shaft shorter on the mugen kit or is the bottom shorter also, just wondering because if the kit is'nt short enough I was thinking of adding the adapter type short shift to the mugen kit. Has anyone done this or think it would be a good idea.
Thanks!
Old Mar 4, 2009 | 11:39 AM
  #60
AnlDyxp_GD3's Avatar
subscribed! =]]
