Anyone running Azenis with 38 offset rims?
Old Apr 4, 2008 | 07:54 PM
MarkB's Avatar
I'm really under the impression that they will rub but not sure. I know that the Azenis are typically wider than other brands. I've got a 16 x 7 rim that's 38+ offset and I want to use a 205/45/16. Anyone else using this setup?
Old Apr 4, 2008 | 08:24 PM
solbrothers's Avatar
i have that exact setup but NOT azenis. i rub in the front on turns and bumps. i did the fender liner trick and still some rubbing on hard turns
Old Apr 4, 2008 | 09:30 PM
JDMchris.com's Avatar
I run THIS
they don t make azenis in 205/45/16
Old Apr 5, 2008 | 08:56 AM
MarkB's Avatar
You're right. Sorry it's 205/40/16 but the width will stay the same. Does anyone agree about Azenis being wider and if there is any rubbing at all currently then I probably shouldn't use the Azenis? ( even though I want to soo bad! )
Old Apr 5, 2008 | 09:58 AM
I run THIS
They dont run wider.... theyre just a different shape.. azenis are more square for ex. [] the falken Ziex is more circular () anywho you should be good with a 205/40
Old Apr 5, 2008 | 01:04 PM
MarkB's Avatar
Dig it!
Thanks guys!
Old Apr 16, 2008 | 04:43 PM
mahout's Avatar
205/45x16 works well on 42 mm offset stock ride height or 45 mm when lowered. Go less than those offsets and you almost guaranteed risk of rubbing
sabawballs
Aug 17, 2012 04:11 AM
fitster
Jul 6, 2010 10:30 PM
Contrabida Face
Mar 12, 2009 12:25 AM
ds62987
Dec 15, 2008 09:36 PM
korky
Apr 22, 2008 05:24 PM
