alloys sizes
Old Apr 8, 2008 | 04:26 PM
keltech's Avatar
alloys sizes
hi all
i need some advice,i'm abit of novice when it comes to cars, i'm buying a silver honda jazz 2003 1.4s this week and i'm after some compatible alloys for it. I just want to know if 17" alloys will fit straight on the jazz or are they to large and i need to stick to 15"? thanks
Old Apr 8, 2008 | 04:32 PM
TOOL's Avatar
17's will Fit(depending on how low you drop). Just make sure you get something with a high offset to avoid rubbing.
Tyler
Old Apr 8, 2008 | 04:55 PM
SD_MR_FIT's Avatar
yes if you go 17's try getting a 45 offset. that way it wont rubb as much...if it does rubb.
Old Apr 8, 2008 | 05:40 PM
mahout's Avatar
Originally Posted by keltech
hi all
Again:
If you use 205/40x17 tires on 17x7/42+ wheels you will be fine unless you lower. Then go 45 mm offset.
Old Apr 8, 2008 | 06:51 PM
SD_MR_FIT's Avatar
YOU HAVE TO LOWER your car when on 17's.
unless you want to be donk...or look like you have a 4x4.
Old Apr 9, 2008 | 02:32 AM
MINI-Fit's Avatar
What about using 17x7 rims with 215/40-17 tires?
Will that work or rub with +45mm offset?
Old Apr 23, 2008 | 08:46 PM
mahout's Avatar
hi all
I have 205/40x17's on 17x7 -42 offset Enkei wheels. No rubbing. If I lowered it I expect it to rub, need -45 mm for that. The 205/40x17 tires are same diameter as stock 195/55x15's so speedo and odo are good. Others like the way it looks so I guess its OK.
dtoxdrift
Jun 23, 2014 12:10 AM
tokenasianguy69
13
Sep 2, 2010 01:11 PM
mkht78
Sep 7, 2009 03:28 AM
braziers
Jan 30, 2009 05:51 AM
diedwater
Feb 23, 2008 04:12 PM
