KraftWerks Supercharger Kit Info v2.1
Old Apr 23, 2008 | 02:56 PM
  #61
leonine's Avatar
Originally Posted by KraftWerks
The ScanGauge will not see boost on the Base kit.
-OJR
can you please explain. if the manifold air pressure is 14.5 now and i add 5psi then why wouldn't it read around 19.5???
Old Apr 23, 2008 | 02:58 PM
  #62
gotfitted's Avatar
omg...the ship date's been pushed to May
Old Apr 23, 2008 | 03:42 PM
  #63
ToyotaLover's Avatar
normal air around us ia 14.5 and manifold pressure is 14.5 hence the reading of 5 additional psi to the manifold would read 5 instead of 14.5.
0 pressure is like space or a vaccum of some sort....forgot the actual logic but it's all 15 years ago science class stuff aka physics
Old Apr 23, 2008 | 06:02 PM
  #64
OJRKraftWerks's Avatar
Former Vendor
The ECU will not see boost. There is a MAP clamp included on the SuperCard.
-OJR
Old Apr 23, 2008 | 06:44 PM
  #65
Former Vendor
This is incorrect.
Don't be confused by Barometric Pressure and Manifold Absolute Pressure.
Atmospheric pressure is approximately 14.7 psi or 101kPa
100kPa = 14.5 psi = 1 bar
0 inHg = 0 psi.
inHg is a common automotive vacuum unit
psi is a common US automotive pressure unit
This is gonna get confusing, so I will talk about what the engine sees.
At Wide Open Throttle on a NA car, a boost gauge will read 0 psi or 0 inHg. The ECU will see only voltage. The voltage is based off of what the pressure transducer in the MAP sensor is capable of.
In our boosted car at sea level, you will see 5 psi on a boost gauge.
I do not know what units or sensor the ScanGauge is reading, but the ScanGauge will not see the boos tin the engine. It only sees what the ECU sees.
-OJR
Old Apr 25, 2008 | 10:45 AM
  #66
Info on the AT setup?!?!
Old Apr 25, 2008 | 11:41 AM
  #67
REXXXXXXXXX's Avatar
Frequent FitFreak Poster
or MT shipping info
Old Apr 25, 2008 | 02:42 PM
  #68
Hondasforlife's Avatar
Lol I Want My Supercharger (at)...............wait I Think I See It No Nope
Old Apr 25, 2008 | 05:48 PM
  #69
Illusive's Avatar
Ahhhh I just updated some account info and checked my order and my pre-order discount isn't showing up
Should I be concerned?
Old Apr 26, 2008 | 02:45 AM
  #70
Former Vendor
No need to be concerned... Your order has processed with the discount already.
-OJR
Old Apr 26, 2008 | 02:49 AM
  #71
Illusive's Avatar
-OJR
Excellent! Thanks for the update OJR! I can't wait to get it! X-ing my fingers that it will be here before my install weekend
Old Apr 26, 2008 | 03:16 AM
  #72
Illusive's Avatar
Just thought of a question, OJR, if I were to get a wideband A/F gauge, will the gauge be reading the A/F that the ECU sees or will it see what is really going on? I know the Super Card adjusts the fuel etc. after the ECU, so I was wondering if there is any benefit with a wideband A/F and if it can actually see the correct A/F reading...
Old Apr 26, 2008 | 09:48 AM
  #73
leonine's Avatar
the a/f meter comes with an o2 sensor. you have to get an o2 bung welded on to your cat pipe (or cat delete pipe). it reads the o2 sensor not the ecu.
Old Apr 26, 2008 | 12:10 PM
  #74
leonine's Avatar
Oscar,
what is the stock a/f ratio?
what is the a/f ratio with the base kit with upgraded injectors?
does chris's car or other cars you used for testing have a/f gauges installed?
jow did you get a/f readings while driving? i assume you were monitoring this because monitoring a/f at WOT vs. real driving conditions are different.
Old Apr 26, 2008 | 12:45 PM
  #75
Illusive's Avatar
Ahh gotcha. I thought you had to tap into the o2 sensor and tie in the wires to the o2 sensor to the a/f meter.
Old Apr 26, 2008 | 12:47 PM
  #76
03DSM-RSX's Avatar
thats the cheap a/f type of gauge. reads entirely inaccurate too. def get a wideband.
Old Apr 26, 2008 | 07:31 PM
  #77
leonine's Avatar
get the AEM wideband uego. that's the one i have. sweetness and comes with a bosch 02 sensor.
Old Apr 26, 2008 | 09:04 PM
  #78
teterman2000's Avatar
CARB questions
Couple of CA smog Q's:
1) If I get the base kit w/ upgraded injectors, how much time would it take to replace the stock injectors every two years? Any other reverse-mods needed to get the thing back to CARB status?
2) If I get CARB-legal I/H/E, then get the base kit (no injectors), do you think the combination will still blow clean enough to pass smog?
3) Will the injector upgrade kit immediately fail a visual inspection? If not (or the tester is asleep at the switch), is there a way to tune the thing down to pass the tailpipe test?
THANKS!!
Old Apr 26, 2008 | 10:03 PM
  #79
VTEC Poppa's Avatar
Hey oscar i just started reading up on this whole thing. i wanted to ask yout 3 questions. 1: Can you give pic with the supercharger installed on the fit?? 2: If you spray nitrous with the supercharger will you blow the motor? (Because i have a friend that is spraying on his fit a 60 shot of NOS) 3: Is There a Software available that raises rev limit and and just air and fuel, and if not is there a possible way to send out the ECU to get tuned?
Old Apr 26, 2008 | 11:56 PM
  #80
SickFit's Avatar
Yo homie. Read all the posts. all your answers are there. And I can guess how Oscar will answer your questions:
1) If he had a pic of the kit he would have shipped the kits out already.
2) Dont spray and run supercharged on a L15 motor.
3) Lost boost just has a Supercard and its tuned for the s/c kit.
