DIY: Install Sound Deadening/Damping
Old Apr 30, 2008 | 12:46 AM
  #121
smeister's Avatar
Originally Posted by toxicavenger
I might try some carpet padding in between my door panels to see if it cuts down on some noise.
If you want to cut down noise, my advise is to put it in the trunk and rear wheel wells.
Old Apr 30, 2008 | 10:28 AM
  #122
toxicavenger's Avatar
hey thanks for the info bro!
Old Apr 30, 2008 | 06:57 PM
  #123
edjosh23's Avatar
Right now the entire inside of my car is in the living room. I am going to be putting some capret padding down, but have had trouble finding info on regular carpet padding. If the carpet padding is not closed cell foam you may have issues with water, when installing in your doors. If someone has some info about which carpet padding to buy that would be great since I will probably be putting some down in the next couple of days.
Josh
Old Apr 30, 2008 | 07:04 PM
  #124
smeister's Avatar
Josh
I dont know where you would but it from since I bought mine from the foam company, but you want CLOSED CELL NEOPRENE. I suggest just asking the guy at Home Depot or Lowes he might be able to point you in the right direction.
Old May 8, 2008 | 01:58 PM
  #125
I did stuff batting into the areas where the tailights are and u can notice the difference of it now. I think eventually I will take the rear panels out and put in some carpet padding.
Old May 29, 2008 | 07:03 AM
  #126
raton's Avatar
It took 3 whole days......but finally finished applying the RAAMmat and Ensolite to the front and rear floors.
It's definitely a bit quieter--less road noise. However, it didn't eliminate as much of the tire noise as I was hoping. I tried to apply as much RAAMmat & Ensolite under the factory padding that's closest to the firewall & front wheel wells.
I'm planning to add R & E to the side kick panels this weekend. Hopefully, this will help muffle some of the tire noise. I'm not too optimistic though...it's such a small area.
I also applied RAAMmat under factory insulation in the engine/hood. It's funny...it seems like I can't hear the engine as clearly when listening to the radio/iPod. I find myself using the tack more now...
Here's some pics:
Day1 - Removed the entire interior...started to rain so had to stop.
Day2 - Applied RAAMmat....Man! This batch was super messy. The Butyl adhesive seemed thinner than my previous orders. It was all over my hands and tools.
Day3 - Applied Ensolite & re-installed the entire interior....then went for a test drive.
Old May 29, 2008 | 08:58 AM
  #127
smeister's Avatar
Wow man, you did a nice job there. You got any pics of the hood and engine area you did? If you think it isnt as quiet as you wish it was then just go ride in a stock Fit you will come back to realize that it is much quieter.
Old May 30, 2008 | 03:10 AM
  #128
raton's Avatar
Thanks smeister. haha. Yeah, you're right...I think I'm unrealistically expecting it to be "crazy" quiet. I'm actually very satisfied w/ the results. I'm really looking forward to upgrading my audio system now. The stock components sound really nice w/ all the sound deadening.
As far as my statement...
...is probably the accumulation of ALL the sound deadening (the floors & under the hood), not specifically due to putting RAAMmat under the hood.
Here's a couple of pics of the RAAMmat applied under the hood. I probably could've put more on, but I applied it as kind of an "after-thought" so just quickly cut deadener in a shape that would not show outside of the OEM insulation.
Old May 30, 2008 | 03:45 AM
  #129
smeister's Avatar
Nice, thanks for posting those pics. How did you get those big plastic plugs off that hold the OEM sound deadening piece on there???
Old May 30, 2008 | 04:28 AM
  #130
raton's Avatar
I used the same trim/clip remover I used to remove most of the trim & panels inside the car. The big plastic clips came off pretty easily w/o damaging them.
It worked great for removing every type of clip I encountered throughout the entire sound deadening project.
Old Jul 18, 2010 | 06:13 AM
  #131
chrisng's Avatar
anychance to see if we can reupload those pics? i know resurrecting from the dead!
Old Jul 30, 2010 | 10:47 AM
  #132
smeister's Avatar
Yeah, I can...I'll try to do it this weekend man.
Old Aug 27, 2010 | 02:48 PM
  #133
kday's Avatar
we should wrap the underside of dashboards with this stuff
Old Aug 27, 2010 | 03:04 PM
  #134
chrisng's Avatar
thanks for doing this man! appreciate it!
Old Aug 30, 2010 | 11:17 AM
  #135
smeister's Avatar
Dang dude...I couldnt find the photos. It's probably backed up on another hard drive. I'll look more later.
Old Oct 17, 2010 | 10:49 AM
  #136
BHLegend's Avatar
I know it's been a while, but where did you get your trim/clip remover?
Thanks!
Old Oct 18, 2010 | 12:31 PM
  #137
smeister's Avatar
Just use a flat head screw driver and cover it with something soft.
Old Nov 19, 2010 | 01:42 PM
  #138
landon fit's Avatar
great write up i might help my friend do this
Old Nov 19, 2010 | 02:16 PM
  #139
chrisng's Avatar
hope you do'nt mind me reposting this, but i couldn't see the pictures but found them on your blog!
Honda Fit DIY and Reviews by smeister13
about 3/4 of the way down.
Old Nov 19, 2010 | 04:12 PM
  #140
smeister's Avatar
Thanks guys! I am glad some people find this post useful.
BTW, my sound deadening is still intact and hasnt fallen apart at all after living in the freezing cold up north and also the hot sun in Florida.
connor55
79
Nov 23, 2022 12:57 AM
kamakurakid
Feb 19, 2009 12:00 PM
Sam Misled
14
Dec 3, 2008 05:22 PM
Evan_2k
17
Oct 15, 2008 01:44 AM
Skibum
Mar 17, 2008 07:28 PM
