Something small - how to change the interior light?
Old Oct 11, 2009 | 03:22 AM
hkfooey's Avatar
I did a search on the forum but can't find anything related to it.
Just bought a new 2009 Fit and get the LED light to replace my interior light bulb (2 at the front, 1 in the middle and 1 in the trunk.
How can I take off those cover without much damage? I am sure there got to be a easier way to do it.
Thanks in advance.
Old Oct 11, 2009 | 09:19 PM
Type 100's Avatar
The ones in the middle and the trunk, you can probably use a flat-head screwdriver to pry the covers open.
The front (map lights?), I'm not so sure.
Old Oct 15, 2009 | 11:28 AM
Black3sr's Avatar
For dome and cargo use a credit card. Interest free too.
Old Oct 17, 2009 | 09:10 PM
hkfooey's Avatar
I was able to open the one in front - but having a hard time opening the cover in the middle - and especially the one in the trunk... HELP HELP!!!
Thanks again in advance.
Old Oct 18, 2009 | 05:56 AM
Black3sr's Avatar
Use a credit card like I said to pry them out.
Old Nov 25, 2009 | 03:45 AM
prens's Avatar
I'm using small knife from my victorinox
a little bit hard for the front, and easy for middle and on the trunk
Old Aug 4, 2010 | 05:21 PM
lowkeymods's Avatar
I'm an idiot please help
I'm also a little stumped...do all of the clear lenses pop out or do I need to remove the whole piece from the headliner on the map lights?
Also, w/ a credit card do I just stick it in a crack and start prying?
Thanks,
The Fit Village Idiot
Old Aug 5, 2010 | 02:49 AM
hkfooey's Avatar
I used a screw driver to get it off - it is relatively easy (after my 4th times).
By the way - I don't think credit card is strong enough...
Old Aug 5, 2010 | 04:58 PM
lowkeymods's Avatar
Ok...so do I take off the clear lense or do I pry out the whole housing...I'm asking this question about the 2 map lights and the dome light.
Thanks!
Old Aug 5, 2010 | 04:59 PM
Krimson_Cardnal's Avatar
Remove the lens.
Old Aug 13, 2010 | 09:53 AM
Punisher11's Avatar
Thanks!
there a slits in the sides of the lens where you can use your pry tool(credit card, whatever) to push out the lens. you only need to push out the lens and not the entire housing
Press Fit
Jul 28, 2023 12:21 AM
cspan37421
May 7, 2012 05:23 PM
larshnordli
Dec 24, 2009 07:42 AM
trancedsailor
Aug 26, 2009 02:28 AM
jaebee
Aug 23, 2008 11:43 AM
