Sponsored by:
Sponsored by:
need advice: dealing with water inside headlamp
Old 11-30-2012, 02:09 PM
Santiad's Avatar
Hey Guys/Gals
I noticed a fair amount of water in my passenger side headlight after I took it to a car wash. Drove around with my lights on and it reduced a bit but today its looking the same as yesterday, making me think its condensation.
I'm about to pick up my air compressor from a friend and blow it out after removing the bulb but wanted to know how did it get in there.
-I never opened the headlights
-I felt around for openings or wet areas and felt none.
-I checked the boot around the bulb and it was dry
Any advice would be appreciated. Its minor but annoying....
Old 11-30-2012, 02:26 PM
SieGunso's Avatar
maybe the seal behind the bulb is cracked or loose
Old 11-30-2012, 03:22 PM
BakedCookies's Avatar
I had this issue in the past on another car, I found the leak, sealed it with silicone, then drilled a tiny hole in an inconspicuous place on the bottom of the h/l and left it like that until it dried out. Then I plugged that hole with some silicone.
Old 11-30-2012, 05:30 PM
Dookoo's Avatar
Size:  1.04 MBI just did an HID projector retrofit and ended up with some condensation. It was easy to remove the condensation. First, I removed all three bulbs (for the condensation to escape). Then I attached a 1" length of rubber hose (3/8" rubber fuel hose or whatever) to the end of my compressor blow tip (pencil/adjustable style) and just opened it a crack to let a small amount of air through which I placed in the lowest, I believe its the turn signal, bulb hole. I checked on it now and then and within 30 minutes, all the condensation was gone. I did not force any water out and just used the air movement to slowly dry out the condensation. I would try and figure out where the water got in. If its from the housing, i definitely would take it back to the Honda dealership to repair/replace.
Old 11-30-2012, 05:45 PM
Goobers's Avatar
Are we all sure the housing doesn't just have a little vent hole?
I know for sure, two of my aftermarket headlight housings (for different cars) had vent holes (tiny tubes that protrude out and point down). I never really bothered to check with OE housings though.
Old 11-30-2012, 06:07 PM
Dookoo's Avatar
Yes there is a vent but no tube. It is a small black plastic cap with a flexible rubber insert to keep water out. It is not a drain hole
Old 11-30-2012, 07:21 PM
Goobers's Avatar
Never said it was a drain.
correllium
06-13-2013 05:52 PM
Cyphron
01-15-2011 11:49 PM
qbmurderer13
07-13-2009 11:44 PM
Luichenwai
11-11-2008 10:32 AM
Quick Reply: need advice: dealing with water inside headlamp
