Sponsored by:
Sponsored by:
09 SPort BAttery Terminal Cover Question....HELP!!
Old 10-25-2014, 08:32 PM
jbsf3's Avatar
Greetings all. I have a '09 sport that has been a great car. I'm in the military and just moved from Korea back to DC. Due to a shipping error, our car took over 4 months to get to us. During that 4 months the car wasn't started except to move it a few times, so the battery died. Somehow during the shipment the large red battery terminal cover that used to be on the battery was lost. I took the car to the dealership today to get the battery replaced as well as the cover, battery was replaced and the car runs great. The dealership said that they don't make a cover that fits my battery because it is not in the same configuration that it left the factory in. I've attached pics (engine compartment was filthy!).
We purchased our vehicle new and the only thing we've ever had done besides oil changes and regular maintenance was a new battery in Korea.
I'd like to get the positive end of the battery covered up with the cover that was on the battery before. Based on the pics, will there be any issues going with the factory battery terminal cover?
Is this what I need? BATTERY TERMINAL COVER (32418-PND-300) - $8.19 - 32418PND300
Appreciate the assistance and look forward to the commentary, thanks much.
Old 10-25-2014, 08:45 PM
john21031's Avatar
No, the picture on the link does not look like the cover on my '12. The one on the picture is too short. Maybe find one on a junk yard? The dealership should be able to order it.
Old 10-25-2014, 08:49 PM
jbsf3's Avatar
Thanks John, if anyone has a link to the correct terminal cover please shoot it to me. Also want to make sure my battery/positive terminal is the factory configuration.
Old 10-26-2014, 12:41 AM
Speedlimitz's Avatar
32418-TK6-003 012 001 COVER, BATTERY TERMINAL 8.03 5.62 Qty:
Old 10-26-2014, 12:42 AM
Old 10-26-2014, 01:54 AM
n9cv's Avatar
At least you got to drive your own car in Korea. When I was there we were not allowed to drive anything except US military vehicles. I had the MPs chase me one on a borrowed motorcycle. Also the MSR south of Seoul was a good 2 lane road to Taegu/Daegu. After that it was all gravel to Pusan/Busan. The only 4 lane road in the country was from Kimpo to Seoul. They were building a 2nd 4 lane northbound to Uijeongbu. Oh yes, officers were not allowed to drive. Only enlisted people were allowed. I do not know about WO's. As you probably can tell that was a long time ago.
COVER, BATTERY TERMINAL | Genuine Honda | 32418-TK6-003
Old 10-26-2014, 07:38 AM
jbsf3's Avatar
Thanks for the links all! Also n9cv, that was a long time ago, great info.
Just to confirm, based on the pics, everything looks factory correct? The tech said that someone added a fuse block above the positive terminal, is that correct or does everything appear factory? Just want to make sure the part listed above will cover the positive lead and the extra fuse blocks. Thanks again!
Old 10-26-2014, 07:42 PM
xxryu139xx's Avatar
the tech has no idea what hes talkign about. that "fuse block" is factory oem. it houses the fuses for the ECU among other things. he prolly never saw what was hiding under the red battery cover.
Old 10-26-2014, 07:59 PM
jbsf3's Avatar
xx - thank you! That is exactly what I was looking for, ordered the cover earlier today, thanks for all the comments!
Old 10-26-2014, 09:23 PM
n9cv's Avatar
the tech has no idea what he is talking about. that "fuse block" is factory oem. it houses the fuses for the ECU among other things. he prolly never saw what was hiding under the red battery cover.
I agree. Mine is broken. I need to also order a replacement. I have a habit of sitting tools, etc. on top of the battery when I'm working on it. So that cover is necessary to keep me from shorting out the battery.
Old 11-10-2014, 10:25 AM
slimchriz's Avatar
I agree, The cover is mandatory. If you blow main fuse you have to buy the whole thing as its not replaceable fuse.
jpsf3 You battery terminal post is either too short or your terminal connection is up way too high. I would make sure its fully seated. If it slides off and makes a poor connection you can blow the main fuse in short order as bad connections pull higher amperage.
Old 11-10-2014, 11:49 AM
jbsf3's Avatar
Thanks Slim, it has been repaired. The battery cable was loose because the shipping company that removed it never tightened it and it wasn't something that I checked before I singed for the vehicle. All good now, thanks!
Jensen Healy
12-06-2019 02:54 PM
pzriddle
01-23-2015 06:31 PM
mozarwasagenius
10-25-2009 07:03 PM
c_kubie@yahoo.com
07-19-2005 09:31 PM
piclistguy@yahoo.com
05-04-2005 11:16 AM
Quick Reply: 09 SPort BAttery Terminal Cover Question....HELP!!
