2nd Generation (GE 08-present)The New Fit... Generation specific talk and questions here.
Welcome to Fit Freak!
Welcome to Fit Freak,
Well Rodge, the resistor did the trick. I knew when you described the problem that it was obvious that the headlamp circuit was backfeeding into the fogs. I used a scotch lock on the combination switch and modified a spade connector so it would fit into the relay cavity, soldering it to the relays' post for good measure. I hate working under the dashes of these tiny cars, so I make sure I only have to do a job once.
so what type of resistor did you use?
do you have any pics so we can see?
also can you describe how it works now
with the resistor in place?
Ok, here goes. I said resistor earlier, which is sortof an improper term for the component I used - if you want to nitpick. A diode allows current to flow in only one direction, unless you go over the specs of the diode will it then allow reverse currents.
The combination switch in our Fits use a common ground. The best I can tell is that when we bypassed the foglight relay control that the MICU provides, the headlight circuit was shunting current through the fog relay - thus keeping the magnetic field closed - keeping the relay "on" when we turned the switch off.
Placing a diode in series on our wire bypass blocks this shunt. I used just a normal 1n4005 diode that anyone can buy at Rat Shack. If you hook the diode up backwards it won't hurt anything in this application, but it won't allow your fogs to come on at will. When you buy them, you'll notice a little white band around the component. This band needs to be pointing away from the switch end of your circuit (in reference to the diode it's self).
Did anyone look into what I posted earlier? G2IC: Teg Tips It would be way easier and you only have to clip 1 or 2 wires. If I had a Fit I would look into it but the dealership won't let me crawl under the dash.
__________________ I ♥ my Hondas
92 integra b16a
95 integra b18c
03 element k24a
coming April-09 tidewater ge
Anywhere to get these schematics? I had it working like this by trial and error - didn't really consider it a solution due to the above problem. Didn't think of the diode idea. I'd like to figure out a way to have them work only with running lights.
i followed ur instructions to the T! only thing i did different was i put a small zip tie on the wire with the spade connector to hold it with the harness to keep it from coming loose, which is what happend the first time i tried it. worked like a charm! thanks Roger's Fit!
well i tried it this afternoon and didn't work. seemed simple enough, but the part where i had to run the wire as a "double L" into the fuse kinda threw me off. i have no idea what this means..
to make matters worse, after putting everything back to original, the fog lights dont come on at all now, although the dash light appears.. seems i really ****ed it up this time
Give me a day or two. I think i have this figured out and can fix for less than $1.
Ok. The fix is inserted into the original post. I don't know about using the resistor, but a diode works, and you still do not have to cut into the original wiring.
The fixes the issue where you cannot turn off the fog lights when the headlights are on.
__________________
09 Fit, MT Navi, door sill trim, Vent Visors, Trunk aplique. Modified Fog lights, modified defrost, modified dome light. DiaLED dome, map and cargo lamp, Honda Low Note Horn, FilterMag, Cargo Mat.
Amsoil 0-20 and EA oil filter.
I think you have told them incorrectly. The diode's band needs to be towards the switch. I have it in now and it works that way.
__________________
OK.. Dumb and Surely a repeat question, but can the fogs be set to cut off when the car is cut off instead of always on?
__________________
2009 Sport AT, Storm Silver Met Mods: OEM Door Visors, Rear Bumper Applique, OEM Floor Mats, Independant Fog mod, Hardwired GPS and Sat radio
I think im gonna try to do this as soon as i have time xD
__________________
______________________________
09 Taffeta White Fit Sport || Tint: Front: 15% Rear: 10% | 8000k HIDs w/ Yellow Fogs | Blue Dome and Trunk Light and Footwell | Swift Springs | K&N CAI | Tinted Tail Lights ||
foglight dependent on parking lights only (foglight mod part 2)
sorry for bumping an old thread but,
Quote:
Originally Posted by FitStir
Yeah, mine works great too, I was afraid I would forget the fogs on since they don't shut off with the car, or give off a warning beep...
I didn't like leaving that part unfinished so I figured out the rest of the mod.
I prefer having the foglights depend on the on/off status of the parking lights
here's the wiring diagram so you get an idea of what's going on, the orange highlighted is Roger's Fit portion, the green highlighted is what you need to do to shut off the fogs when parking lights are turned off.
While you have the steering column cover removed, go ahead and remove the headlight stalk as well by removing the harness connector and these two screws.
On the headlight stalk, pop these 4 clips, but becareful after doing one side the cover likes to fly off into oblivion.
What you'll see is this, locate the green and gray wires.
Cut and tap like so.
Now the foglights can only turn on if you have at least the parking lights on, therefore retaining an audible reminder if you leave it on after parking & shutting off the car.
__________________
2006 WRB GDF - track & mountain
1987 Panda AE82 FX16 - daily beater
2009 OR GE8 - wife's
