How do u remove map lights?
Old Feb 6, 2009 | 04:56 PM
CrystalFiveMT's Avatar
Just when I had my last annoying rattle fixed (glove box), another one made its debut.
On the choppy freeway, only if the sun is out (my car has been silent the past 2 rainy days) I think I hear some crackling sound from the map light assembly. If I push upwards around the lights I'll hear a few different crackly noises. I can slip the edges of my fingers under the map light plastic frame, but I don't want to pull and break anything.
I'd like to remove the maplights to have access to the noises. Anyone know how to do this correctly?
Thanks.
Old Feb 6, 2009 | 06:02 PM
concorde's Avatar
I replaced all my interior bulbs to led's recently. Use a small screwdriver and carefully pry off each map light from the inside section. They are attached by "hinges" that if removed very carefully, will not break off for good. Once you see how the inside section works, it will be easy to remove the entire light cover. Repeat for the other side.
I'd recommend doing this in daylight or simply turn on the map light itself. Again, have patience with this econocar and it's "cheap" parts...
Old Feb 6, 2009 | 06:18 PM
Thanks a bunch! I'd give you another +rep but it says I can't yet.
Old Feb 6, 2009 | 06:23 PM
concorde's Avatar
ha, that's ok, just give it to somebody else ..good luck with finding all those dastardly rattles!
Old Feb 6, 2009 | 09:47 PM
Thanks for photo too! I'll prolly do this tomorrow.
Old Feb 7, 2009 | 05:02 PM
Just dismantled the map lights and applied felt to contact areas. It was easy. Thanks for the tip and photo again. I didn't take a ride yet, but when I pressed upwards in that area it was silent, so here's hopin' that did the trick.
Old Feb 7, 2009 | 06:29 PM
dman's Avatar
Thanks.
How did you fix the glove box rattle???
Old Feb 7, 2009 | 08:16 PM
concorde's Avatar
You're welcome
Press Fit
Jul 28, 2023 12:21 AM
kitkit201
Nov 26, 2012 11:32 AM
Grayfox
Aug 2, 2012 09:01 AM
White_GE8
Jul 14, 2011 08:03 PM
qbmurderer13
Jan 30, 2009 12:54 AM
