Replacing the H11 Foglight Bulbs
Old May 12, 2009 | 05:54 PM
Benggolf's Avatar
Question Replacing the H11 Foglight Bulbs
Would like to replace the standard H11 55W bulb with a yellow halogen bulb. Came across these Nokya H11 80W bulbs:
Micro Image : NOKYA H11 80w Arctic Yellow bulbs
Anyone here have any experienced with these? Any risk of the OEM
wirings overheating with these 80W bulbs?
Please note that there is a HD wiring harness available for the high output Nokya H11 bulbs for the Toyota Yaris. Will this connect properly to our main harness (plug & play)? Here is the link:
Micro Image : NOKYA H11 plug 'n play wiring harness
TIA for your input/comments.
Old May 12, 2009 | 07:31 PM
halfmoonclip's Avatar
Eighty watts SHOULD be within what the wiring will handle; rule of thumb elsewhere has been 100w with standard wiring.
There is a voltage drop that diminishes the power reaching the lights if they are wired thru' the headlight switch. Do we know if the headlights/foglights are wired thru' relays? I hear underhood clicks when activating the lights, but haven't tracked 'em down yet. Without relays, bumping the wattage may not get you any more light.
I do run yellow bulbs in the fogs of the Jeep; don't know that it makes a huge difference in performance, but it lets opposing motorists know that they are fogs, not driving lights....some see an extra set of lights, and jump to conclusions.
Moon
Old May 12, 2009 | 08:29 PM
MR-GE8's Avatar
I have these on my car right now. Been using them fine for about half a year now with no problems. The h4 arctic white however.. Burnt out after 2
Edit: sorry. I have the 55w ones. Read the thread too fast.
Morair
May 9, 2012 08:26 AM
sdiesel619
Oct 18, 2010 01:21 PM
Benggolf
20
May 20, 2009 06:42 PM
sLiVeRwOrM
28
Feb 25, 2008 04:58 PM
pedaler
Nov 28, 2006 11:51 AM
