License plate reloctor on GE8?
Old Aug 3, 2009 | 08:40 PM
jquan23's Avatar
is there a DIY or one that i could buy online? I have trouble looking for one. All of them are for the GD3
Old Aug 3, 2009 | 11:20 PM
jquan23's Avatar
im guessing its a no on that?
Old Aug 3, 2009 | 11:23 PM
dela's Avatar
there's an adjustable one that you can buy from autozone... the company that makes it is bell...
it requires to drill into the bumper... but you can drill underneath the top of the lower grill and you cant see it...
i personally think it looks cleaner then the stock one, less to look at... i angled it but you can make it so its the same position as the stock one or even put it on off centered like some GDs have..
Old Aug 3, 2009 | 11:48 PM
jquan23's Avatar
hmm, thats the problem, ive seen ones that require drilling. i dont want to drill any holes into my bumper tho.
I was looking for something that is simple bolt and done.
Old Aug 4, 2009 | 12:25 AM
dela's Avatar
there are some GD brackets that use the tow hook.. im pretty sure u can use those...
but the drilling isnt really much... if i took it off it'd look stock and you cant tell its drilled unless you know what you're looking for... very small holes
Old Aug 4, 2009 | 01:06 AM
Wongawa's Avatar
Password JDM makes a bracket to relocate the front plate. Will it work?
Old Aug 4, 2009 | 07:55 PM
jquan23's Avatar
you would need to drill atleast one hole in order for you to hold the plate securely. The mounting holes are too close together.
I think i might end up just drilling one hole in order to fit the brackets that are used for those types of kits.
akapur
16
Nov 16, 2015 02:43 AM
kage
Jan 17, 2011 05:16 PM
Retrofit09
Sep 24, 2009 01:52 PM
YA2_user_GD3
May 27, 2008 01:18 AM
DrDiff
Mar 22, 2007 12:04 PM
