I want to slam my GE
Old Sep 12, 2009 | 01:42 PM
Watsoff's Avatar
Originally Posted by B1str0
if you can scrape a stock height fit then something is wrong lol
maybe the driveway is too steep?
Old Sep 12, 2009 | 02:43 PM
B1str0's Avatar
RubberBabyBuggyBumpers
well if you bought a house with a drive way like that then something is STILL WRONG lol
Old Sep 13, 2009 | 07:03 AM
Lek's Avatar
Lek
Just fit a set of these BC Coilovers, Standard height - 3", F 5k & R 4k. They really plant the car to the road nice and firm, not hard. Softer springs can be ordered I think, but I find F 5k & R 4k Ok. They don't feel as hard as I thought they would.
Old Sep 13, 2009 | 10:39 AM
Marian's Avatar
Actually it's not. My driveway has a slight rise and I back out and enter at an angle. I still sometimes scrape with my stock 09 sport.
Old Sep 14, 2009 | 08:01 AM
bensenvill's Avatar
Originally Posted by mike2100
interesting story but definitely cannot be taken as a rule of thumb
What kind of car was it? If it was something already neutrally handling/setup well from the factory then yes any uniformed alterations can totally screw it up.
I just post it up as a case-in-point. Its a 99 cougar with d2s (11k front, 9k rear) and many other suspension goodies. obviously when you put coilovers on, you want to see how low you can take it... over a few months I slowly bumped the car back up to stock ride height. on that car, anything a 1/2" lower than stock really is a detriment to handling. I played with so many different combinations of parts trying to get it to work well with a strong drop but it just fundamentally ruins the suspension geometry.
Old Sep 14, 2009 | 11:30 AM
Lek's Avatar
Lek
My BC coilovers are awesome. I run them at F 20mm/R 30mm lower than stock, but they can go heigher. The car feels like a hovercraft, ever so smooth and nearly zero body roll. As for the shocks, I run them at F Soft 5 clicks / R Soft 6 clicks. I have the option to go all the way to 30 click, but I never will. You can't compare D2 & BC Coilovers.
Old Sep 14, 2009 | 11:37 AM
bensenvill's Avatar
just because it feels like a hovercraft and has no body roll doesn't mean it will product faster times on the track.
Old Sep 14, 2009 | 09:58 PM
Lek's Avatar
Lek
I have never had it on a track, but it feels great for daily driving and a bit of fun when needed.
Old Sep 14, 2009 | 10:05 PM
kingofpicklez's Avatar
+1 on the d2 coilovers, im ordering them from assaultech.
Old Sep 14, 2009 | 11:10 PM
Lek's Avatar
Lek
Good Luck!! Let us know how they feel.
Old Sep 14, 2009 | 11:18 PM
dela's Avatar
thats where RCAs come in
Old Sep 14, 2009 | 11:33 PM
  #32
Lek's Avatar
Lek
BC's can go 3.5" below from standard height, but no Fit could drive that low.
Old Sep 15, 2009 | 11:20 AM
  #33
bensenvill's Avatar
no it has all the goodies, custom tubular adjustable control arms (front and back), toe arms, plethora of sway bars to play with and more heim joints than you can shake a stick at, all mounts are solid including subframes, lots of seam welding, welded sub frame connectors and other bracing. It added a bit of ride harshness, but was still great on the streets.... if theres one lesson I took away with that suspension build, don't go nuts on spring rates when getting coilovers, it'll really kill your ability to safely drive it on the street.
(although when your springs have no deflection, you can get the car stupidly low without ever worrying about the tires rubbing).
also I don't know how much it affects the fit, but if you do decide to go stupidly low, you are shortening the distance between the wheel hubs and the transmission, and if you hit something, you run the risk of binding and snapping the cv joints.
(ok those BC coilovers look amazing... I like that alot better than the D2 designs)
Old Sep 15, 2009 | 11:35 AM
  #34
Lek's Avatar
Lek
They don't just look good, they also feel good. That's the most important part for me. I am only about 25mm/30mm lower right now with 5/6 clicks soft and the car controls itself, way better than stock.
Old Nov 9, 2009 | 01:12 AM
  #35
clay7160's Avatar
same thing they said about my bagged ls430.....the difficult i can try now..the impossible might take a little time..
Old Nov 9, 2009 | 11:48 AM
  #36
beangrower's Avatar
^heh, i remember seein that vid over at club lex. so u have a fit too?? or jus browsin' around.
i had a bagged ls430 also. im thinkin' about bagging my fit..but don't want to spend the $$$.
Old Nov 9, 2009 | 12:13 PM
  #37
clay7160's Avatar
my bro now has the ls430.....i have a ls460 that had jic coilovers..that i am selling car today...and looking to pic up a 2010 taffeta white sport....to replace an 03 honda element that i am also selling....so i will be a 1 car household again...2010 fit......most people think i am crazy to get rid of the ls460, but it kinda scary modding a 70-80k car, plus i am selling it for what i have in it........plus the fits look cool...
Old Nov 9, 2009 | 12:21 PM
  #38
Why slam a already bumpy riding car?
XxPuNTeRxX
May 1, 2014 11:25 AM
AtticusFit
Sep 4, 2010 12:16 PM
blackidz
Aug 4, 2010 09:08 PM
drock305
Mar 18, 2010 08:55 AM
pastafarian
Nov 20, 2007 09:24 PM
