2nd Gen GE8 Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 2nd Gen GE8 Honda Fit
DIY pics: Painting rear valence/diffuser (2nd day with the Fit and i painted it!)
Old Nov 6, 2009 | 10:10 PM
Vash's Avatar
EDIT: UPDATED on PAGE 2, Post# 32
The Update is how the paint looks now, after 7 months, and also better angles to to guide someone with taping if they needed to.
2010 Fit Sport Manual
second day. already thru 120 miles on the car sinse i bought it. and i felt i was about crazy when i took sand paper to perfectly good paint.
Tools used:
Painters Tape 3/4th inch
Rustoleum Satin Black (kinda like a flat black color) I did about 3 coats, a few minutes apart from each other, just like the directions on the spray paint can.
News Paper
Sand Paper
stock:
heres what i used:
prep (taping and sanding surface to be painted):
that blue tape is painters tape.. beleive me i done it before without painters tape and alot of the paint will come off when you pull off non-painters tape after painting
spray:
remove:
results:
whole car results:
Old Nov 6, 2009 | 10:20 PM
drock305's Avatar
looks good..
Vanct's Avatar
Nice job, how many coats did you put on?
Old Nov 6, 2009 | 10:27 PM
Vash's Avatar
about 2... some parts of it about 3 coats.
i done this before with no sanding and it chipped after 3 years (also did like 6 coats.. might be too many). and on the same car i done it on, i also painted the hood with sand paper with about 3 coats, and it never chipped after like 5 years (lost track of the car afterwards because i sold the car to someone else).. with the same paint as well.
so i learned my lesson, and iam posting my mistakes i did in the past too to help prevent anyone else from messing up. This time i did it perfect, but this is also like my 4th time doing something like this.
i would say low coating with sanding the surface before hand gives the best results and longevity. The more coats, the more likely it chips i beleive.. i hope someone can confirm that.
i also beleive you can replace sanding the surface down and using primer instead.... but i never used primer before, and i had many sources tell me that sandpaper also does the same job, because it creates a rough surface for the paint to really stick.
Old Nov 6, 2009 | 10:29 PM
Btrthnezr3's Avatar
Wow...that looks fantastic! I want to do this so bad, but I'm waaaaay too nervous to do it myself! Kudos to you!
Old Nov 6, 2009 | 10:41 PM
teamkitty's Avatar
Congrats man for having the balls to do it, and for having the skills to do it right. Really impressed with the turnout. Great job!!!
Old Nov 6, 2009 | 11:13 PM
Virtual's Avatar
You blanked out you plate in your first thread but not here. I guess you could edit them.
Old Nov 6, 2009 | 11:25 PM
beangrower's Avatar
what grit sand paper did you use?
Old Nov 6, 2009 | 11:42 PM
Vash's Avatar
idk it was just left over sand paper.. maybe 100 and a 400 for the hard the reach places? i already thru away all the sand paper today. and it was just leftover sand paper i had laying around.
Old Nov 6, 2009 | 11:53 PM
JDM-Taffeta-S's Avatar
look awesome but i would be scared. lol
Old Nov 7, 2009 | 12:36 AM
kurogold's Avatar
oo nice
i did the same couple months ago
but instead, i used plastidip (just in case i ever want to remove the paint, i could)
its still holding well =)
Old Nov 7, 2009 | 01:18 AM
90 DGRZ's Avatar
looks great on a white car. if you want, some people buy super thin black pinstriping tape to tape over the edge for a crisp straight cut, and will most def resist chipping.
in NC they give you ur lic plates right when you buy a new car? it's been a month for me and i still got paper plates.
Old Nov 7, 2009 | 01:53 AM
Vash's Avatar
nope that came off of my mustang, i think they gave us 14 bux for not creating a new one.
just saved the old plate off of the mustang, and transfered insurance and DMV info the day i bought the car. but i don't have my "official" registration papers yet
i actually tried that on my mustang a while back the black pin stripping and it still took off some of the paint when i pulled the tape, but it wasn't by much. but i used actual pin stripping tape and not one for painting over tho, i wish i had pics of where it messed up, but i painted the rest by hand to fix it:
Old Nov 7, 2009 | 04:14 AM
wpyeo's Avatar
well done on the paintwork! a JDM GE8 RS lookalike!
Old Nov 7, 2009 | 05:16 AM
90 DGRZ's Avatar
sick stang. how's life in the slow lane?
lol
Old Nov 7, 2009 | 11:11 AM
Vash's Avatar
lol
that was my first stang, heres my latest one that i sold last month:
Supercharged and Intercooled Mustang GT 02 - SVTPerformance
Old Nov 7, 2009 | 07:01 PM
Spiritborn's Avatar
Thumbs up
Good job, that's how I did mine.
Old Nov 7, 2009 | 08:12 PM
Perrenoud Fit's Avatar
If it doesn't move..... Paint it!!
Nice Mustangs ............... The reason for sanding is it cuts a tooth in the surface for the paint to bond into. If your spaying a color coat then the sandpaper should have a high # if your using dry paper 240-320 grit but if your wet sanding then you can go even finer 600 grit then clean the area with a paint prep to eliminate fisheying and spray away!
And you are right Vash with the thought that too many coats or to heavy a coat is better, it's Not! When sraying wether it's a rattle can or a HVLP gun you look for the moment that the coverage (paint) "just flows out" and stop!! You have to be looking at the correct angle with a good light source, and the first coat is called a tack coat this is really important, it's not meant to be a finish coat. The tack coat is lighter (less material/Paint) and is sprayed on the surface to hold the gloss/finish coats.
I know,I know it's that I've been painting stuff for years and years and I just was going to say Nice Job there Vash, Great visuals for 5 bucks and 2.5 hours. Good Work!!
Color is the cheapest way to make the biggest effect on AnyThing............. like anything the more you do it the beter it turns out.............................. Cya'll
Old Nov 8, 2009 | 05:09 AM
90 DGRZ's Avatar
super nice. that thing basically paid for the fit!!
Old Nov 8, 2009 | 08:22 PM
Koala Yummies's Avatar
Nice writeup. I saw a few other people do this, and the RS looks good with that portion black which made me want to do it, but this thread finally motivated me. I spray painted that area today, used the same masking painters tape. I removed the black plastic stuff under the bumper, the muffler tip and the visible clips and wrapped everything in newspaper like you did. I sanded with what I had (800 grit) but used Rustoleum high-heat BBQ paint, its pretty much flat black. I probably spent about an hour on the masking portion, trying to get the lines perfect was a pain but the black pin-striping idea sounds great to finish it off.
Thanks for the ideas and motivaton
