Gasket Question
Old May 10, 2008 | 09:24 PM
thedeadpoet000's Avatar
Gasket Question
I'm putting back on the Fit's stock exhaust but I can't remember if there is a gasket between the muffler and the b-pipe. So, two questions:
1) is there a gasket between these two parts?
2) if there is a gasket, could I run the car without it ? Or is that just stupid?
Old May 10, 2008 | 09:28 PM
kelsodeez's Avatar
UNBANABLE
its called a donut gasket. it looks like a metal donut
your exhaust would not fit properly if it wasnt in there. you should get under there and check for exhaust leaks anyway.
Old May 11, 2008 | 05:17 AM
claymore's Avatar
You could run the car without it while you drive down to your local dealer to get one, no really your connection bolts may not be able to be tightened all the way but some people are running with no muffler with no ill effects.
Look on your old muffler parts the gaskets are hard to see and getting them off is not easy so the one you are missing may be stuck on your old parts.
Allyoopski
Nov 10, 2016 08:17 PM
Desmond Lamar MacRae
Jan 22, 2016 02:34 AM
EMC2
Mar 19, 2011 05:22 PM
kancerr
13
Mar 30, 2008 12:13 AM
lee_hacken
May 1, 2006 06:30 AM
