help with HID fogs
Old May 10, 2008 | 06:49 PM
marcryan27's Avatar
help with HID fogs
has anyone here installed a HID foglights? can someone help me cuz i got one but i cant seem to figure it out hehehe i tried searching for a DIY but no luck.
thanks!
Old May 10, 2008 | 09:50 PM
AtticusFit's Avatar
what kind of help you need?
Old May 10, 2008 | 10:32 PM
kelsodeez's Avatar
UNBANABLE
get any type of hid kit that is an H11. if i were doing this i would go with 3500k for the fogs bc they are yellow.
Old May 10, 2008 | 11:06 PM
jman245's Avatar
do hids feel any hotter on the fogs?i had the yellow film on the fogs and replaced the bulbs with the yellow nokya ones and they burned them(film) cause the got too hot.
Old May 11, 2008 | 04:55 AM
marcryan27's Avatar
i need something like a DIY. i got h4 3500k from xenith but i cant figure out the wirings and how to take the bulb out from the fogs.
Old May 11, 2008 | 05:10 AM
kelsodeez's Avatar
UNBANABLE
pm me and i can explain it to you but H4's wont work in your foglights. H4 is for your headlights. your fogs are H11.
Old May 11, 2008 | 05:15 PM
marcryan27's Avatar
im sorry i mean H11...
Old May 11, 2008 | 06:55 PM
marcryan27's Avatar
does anyone know where i would connect this? i know its for the ground but im not sure though... can anyone help me.. specially those with xenith fogs installed.. any help will be greatly appreciated hehehe
i connect the other end to the ballast but i dont know where to put the other end...
Old May 11, 2008 | 08:10 PM
AtticusFit's Avatar
one goes to the hot side of your factory harness and the other goes to the ground side. best thing to do is pull the factory bulb and use a test light and switch fogs on to find which is power and ground.
Old May 11, 2008 | 08:11 PM
AtticusFit's Avatar
oh yeah white should be the power side on the kit that you have.
Old May 11, 2008 | 10:45 PM
marcryan27's Avatar
where do i connect that?? hehehe im not mechanically incline thats why...
Old May 24, 2008 | 07:10 PM
F'it_ImFromTx's Avatar
i am having the same problem. i got my h4 kit on in less than 30 minutes. i know how the system is supposed to be wired but the metal spades dont fit into my factory harness. is there something that im not doing right? are the spades supposed to just slide in? because the ones supplied with my kit are about twice the size of the sockts on the factory harness.
Old May 24, 2008 | 09:12 PM
japspeed's Avatar
they should just slide in, check to see if any of the slots are different sizes, i just tried different slots until they worked. its not going to hurt anything if you hook them up backwards they just wont work.
Old May 24, 2008 | 09:48 PM
azncarbos's Avatar
true they do just slide right in.
Old May 25, 2008 | 08:46 AM
i actually figured it out last night after work. the spades were to big to slide into the stock harness so i filed them down so they would fit. it took me like ten minutes doing it with a little nail file i found in my garage. but i got them hooked up and running.
Old May 25, 2008 | 05:03 PM
marcryan27's Avatar
so you just file those 2 metal thingie and slide it into the harness from the stock fogs? can you post a pic of it.. just curious. maybe i can do it on mine
Old May 25, 2008 | 06:44 PM
yea ill try to get some pics up for you by the end of the night.
Old May 25, 2008 | 10:49 PM
well here are a fe pics i took. forgive the poor quality i took them with a camera phone,
xonexlifex
Jul 15, 2010 04:04 PM
cKranez
Apr 23, 2009 07:58 PM
Canadian_R32
14
Mar 13, 2009 02:43 AM
08_Nick_Fit
Oct 5, 2008 07:26 PM
gn-it&rn-it
Aug 1, 2007 02:08 AM
