Lightened Crank Pulleys with KWSC
Old May 25, 2008 | 08:45 AM
dman77fb's Avatar
is anyone running lightened pulley with kwsc? also wondering if anyone is running the weapon r intake manifold? if you gotta pull the top if the stock manifold as it is, it kinda makes sense to swap out the manifold at the same time. just wanna know if it's working as well as hoped. if you don't wanna announce to the forum, pm is ok. (big brother is always watching... )
dave
Old May 26, 2008 | 11:58 AM
eldaino's Avatar
dave
the kit was designed to work with the stock pulley.
Old May 28, 2008 | 01:24 AM
xorbe's Avatar
it would be nice to know if that's just "the company stance", or if KW has specific negative feedback after having tried an after-market pulley themselves.
Originally Posted by gotfitted
haha yea, my hoses were installed bass ackwards and long story short, the car ran like junk ...
holy cow, how did that thing even run!! at least the spark plugs were still in the right order.
Old May 28, 2008 | 02:01 PM
dman77fb's Avatar
the l15 was also designed to run with te stock crank pulley, but that didn't stop the aftermaket...
dave
Old May 28, 2008 | 02:51 PM
JDMchris.com's Avatar
I run THIS
dave
Aftermarket crankpulley on the SC can alter settings on the SC. It might cause unwanted problems when using in conjunction with the Kit.
Old May 29, 2008 | 02:54 AM
claymore's Avatar
If a stock circumference pulley of a lighter WEIGHT (which most of the many brands are) is installed it could NOT have any effect on the supercharger system. It does not alter the speed or any other operating parameter of the supercharger.
The only thing to be concerned about is whether or not your new pulley has been designed to operate safely with the additional stress of the force necessary to turn the supercharger imparted to the pulley by the automatic belt tensioner
Old May 29, 2008 | 12:38 PM
OJRKraftWerks's Avatar
Former Vendor
dave
True, but that doesn't always mean it's right. The dampening of the stock crank pulley is important for the engine. There have been many articles about this. The Society of Automotive Engineers (SAE) has talked about this many times as well.
Here is a small article: ATI - The Dangers of Power Pulleys & Understanding the Harmonic Damper
-OJR
Old May 29, 2008 | 01:08 PM
claymore's Avatar
That article would be nice if it applied to a Fit.
But since the Jazz/Fit has JUST A PULLEY NOT A HARMONIC BALANCER it doesn't matter what the problems are in the article because that is NOT the system that the Jazz/Fit uses.
Once again on the Jazz/Fit it's JUST A PULLEY nothing to do with the balance of the engine (Jazz/Fit is internally balanced). It's there to drive the belt no harmonic vibration reduction what so ever.
Old May 29, 2008 | 02:07 PM
eldaino's Avatar
i'm sure that they have put some thought into it. otherwise claymore, i think its best we take the jacksons word....the people who would agree with you will probably also be the ones wanting their money back when their stuff breaks because they didn't follow directions because they thought they knew so much.
Old May 29, 2008 | 03:38 PM
Former Vendor
That article applies to engines in general.
If you take a look at the stock crank pulley, there is dampening material sandwiched into it. Take a close look...
So there is harmonic vibration dampening built into the stock crank pulley on the Fit. Honda would not use a solid crank pulley.
-OJR
Old May 29, 2008 | 07:19 PM
jpax's Avatar
Eldino here is a pic of what Oscar Jr. Is talking about
this is a honda pully, and here is the materal in that hes talking about. see how that razor blade is sticking in it. Rubber like materal used to dampen
Hi Oscar
don't you have my old engine still? take pics of that lol or did you blow it up?
Old May 29, 2008 | 07:27 PM
Former Vendor
Thank you for the pictures jpax!
No, we did not blow it up! Actually, your engine is pictured front and center in our instructions.
-OJR
Old May 29, 2008 | 07:36 PM
jpax's Avatar
Awesome good to hear.
Is Kraftwerks going to have a Booth at Sema this year? or is that underwraps?
Old May 29, 2008 | 07:39 PM
Former Vendor
Under wraps...
-OJR
Old May 29, 2008 | 07:48 PM
jpax's Avatar
Well can't wait till afterward for a little action. remember this old photo! Talk to you later.
Old May 29, 2008 | 10:48 PM
xorbe's Avatar
(Read my mind about splitting these posts into a new thread!)
Got the UR pulleys today -- my scale says 461g for the crank and 87g for the alt pulley.
Old May 30, 2008 | 03:21 AM
claymore's Avatar
-OJR
The Jazz/Fit engine pulley is just that a pulley is serves no function in relation to harmonic damping and is not a harmonic damper it's just a pulley so that article is not relevant to Jazz/Fit.
Old May 30, 2008 | 03:31 AM
claymore's Avatar
I went through the threads and the only posts Deleted were deleted by the OP as far as I can see.
One of mine was "Missing" also???? What only certain people with positive posts allowed to post in this thread??? Even to correct incorrect information???
Old May 30, 2008 | 03:35 AM
claymore's Avatar
Actually that rubber is for reducing NOISE AND harshness not harmonic damping. Read the manual even "gods of performance" are incorrect sometimes. You could run the Jazz/Fit engine WITHOUT a pulley with no ill effects it's JUST a pulley to drive the belt.
Old May 30, 2008 | 03:43 AM
claymore's Avatar
from KW post # 10 "That article applies to engines in general."
I guess you don't believe another manufacturer either........
From Unorthodox Racing Nice SOLID pulley but hey I guess you know more than them??? But they think it's OK to run with a solid pulley on the L-15a engine but you don't believe them either I bet.
photo credit:xorbe
Don't make any more of an A** of yourself by ASSUMING something that you have no clue about.
