Sponsored by:
Sponsored by: CARiD
radiator hoses wrapped?
Old Jun 24, 2008 | 09:55 AM
07fitsport's Avatar
can you wrap the radiator hoses in header thermal wrap to keep the heat from them radiating out to the engine compartment esp if you have an aftermarket intake that the filter is close to it???
Old Jun 24, 2008 | 04:20 PM
seeremlive's Avatar
Not a good idea. The hoses give off heat and assists in cooling the engine. Also the rubbe the hoses are mad of have a limit on heat handling. Insulating them could raise the temp above this limit.
Besides, all of the heat from the radiator and AC condensor are pulled into the engine compartment and out under the car. So would wrapping less than 2 feet of hose help?
Old Jun 24, 2008 | 04:23 PM
07fitsport's Avatar
wondering how to block heat from hose to the cone filter using a custom cai that put filter close to the radiator hose..
guess have to make a shield between hose and filter or custom box to go around the cai or filter
Old Jun 24, 2008 | 04:30 PM
seeremlive's Avatar
I have seen some of the cone filters with a sheild on three or four sides to keep heat away. I had on on my 2000 Dakota. Here is what the K&N looks like.
http://www.knfilters.com/search/prod...Prod=77-1516KP
john21031
Nov 26, 2015 01:39 AM
Maty J
Sep 14, 2013 12:35 AM
413FIT
17
Mar 23, 2013 09:18 AM
alvarospatchez
May 17, 2010 02:35 AM
