battery problems and headlight problems
Old Jul 30, 2008 | 06:37 PM
khanhdom's Avatar
I have hids 4300k and for some reason my right headlights turn off randomly. It looks like my battery is maybe weak or something and doesn't have enough juice? Does anyone have this problem? I notice that when I have the HID headlights on and radio on, I can't turn on the roof light, but I turn off the radio, and it works. Sounds like I need a new battery?
Old Jul 30, 2008 | 06:45 PM
Fitcapo's Avatar
car should be too new to need a new battery...... maybe your screwed up some wiring or something.
Old Jul 30, 2008 | 07:02 PM
xonexlifex's Avatar
thats kinda wierd, i had the same problem when i first put my 6000k hid kit on, it was only the right side and it only would happen when i turned them on, only one would turn on and the other one wouldnt, i reconnected everything and wrapped electrical tape around the connector to the stock wiring harness and now it works perfect, i dont know what it was from but they work now, id say reconnecting everything and dont reset ur battery or anything the second time either, i did that the first time and i thought maybe it was bec i reset the battery so when i reconnected it i left the battery alone. i hope this helps
Old Jul 30, 2008 | 07:20 PM
khanhdom's Avatar
hmmmm thanks one life, i'll reconnect everything and try it
Old Jul 30, 2008 | 07:56 PM
LOZA's Avatar
Im not sure if its the same, but that happened to me with my HID fogs on the right side too. At first I thought it was my ballast or bulb, but I reconnected everything and it works just fine.
Old Jul 30, 2008 | 08:26 PM
Fa1's Avatar
Fa1
Sounds like it could be a grounding problem. I'd suggest checking the right grounding point first before disconnecting things.
Old Jul 31, 2008 | 11:50 AM
khanhdom's Avatar
the ground is connected good so it can't be that.
Old Jul 31, 2008 | 09:32 PM
xonexlifex's Avatar
ya mine was a direct plug and play so i didnt have to ground it anywhere, maybe its just bec its a new kit and needs to get use to running for while, like i said, i reconnected everything and it all works good now
pzriddle
Jan 23, 2015 06:31 PM
usert_l
Jun 25, 2014 05:17 PM
Mini_Odyssey
Apr 21, 2013 07:37 PM
N.O.R.M
Mar 31, 2013 12:23 AM
mdsniper7
Dec 7, 2012 05:35 PM
