Interior illumination dims? Battery issue?
Old Apr 14, 2013 | 06:16 PM
Mini_Odyssey's Avatar
The other day i was driving at night and i notice in the corner of my eye the climate and radio illumination would dim whenever my trans shifts or rpm drops near idle. My car starts fine, doesn't hesitate but i do recall sometimes the battery will work fine like that but when you do a quick amperage draw it will fail on its ass. My old 2003 4runner had a original Panasonic battery which worked and started fine but since the 4runner has a electric brake booster (which draws alot of current) my headlights used to dim when it engages and recharges the assist. My 4runner battery never did die, i ended up replacing the battery anyways and then i noticed the problem when away. Im wondering if my Fit's battery is showing signs of that weakness.
Old Apr 14, 2013 | 11:16 PM
fujisawa's Avatar
I know when I apply the brakes my headlights dim. I mostly notice this when sitting in the driveway; while driving there's too much going on to notice.
My older cars never used to do this. I don't think this is a design flaw though. I think it was considered acceptable. I'll just say this: In a Land Rover, I suspect this would not be considered acceptable. I'm OK if a Japanese subcompact has lower standards for 50% of the average US new-car cost!
Old Apr 15, 2013 | 12:44 AM
I don't consider it acceptable for a modern automobile, maybe a old car from the 70s but nothing modern. Even the many motorcycles I've had never did that, with the exception of 1 which would only dim when the electric fans came on otherwise it would never fluctuate.
Old Apr 15, 2013 | 12:52 AM
DrewE's Avatar
It's perfectly normal behavior. When the engine is idling, the alternator cannot put out too much electricity, so the car's electrical system is running mostly off the battery. The battery's voltage when discharging is always going to be lower than the voltage required to recharge it (such as happens when the engine is running at speed). Possibly the interior illumination circuitry of the Fit is more sensitive to voltage differences than in some other vehicles for some reason, making the voltage variations more immediately obvious, but within reason they're nothing to be concerned about.
Old Apr 15, 2013 | 12:58 AM
The part i find odd is, it doesn't do it with things like turn signals working which you'd think would fluctuate voltage, it seems to do it mostly when the transmission shifts up a gear or when rpm drops below 2500 which it does when it shifts. But if I let it sit at a stop light with signals on doesn't even faze it which boggles me. How much power does a trans solenoid suck up during a shift? I don't ever notice my buddies fit do this and we both have 2012 sport models.
Old Apr 15, 2013 | 02:05 AM
Red 05's Avatar
I think the reason mine dims is when the AC compressor kicks in, it draws enough amps to dim everything.
Old Apr 15, 2013 | 03:29 AM
spreadhead's Avatar
You can get your battery tested free at many places, Wal Mart, Autozone, Batteries Plus, etc.
Old Apr 15, 2013 | 03:58 AM
loudbang's Avatar
Honda electrical systems are engineered to run at the lowest voltage output from the alternator to save fuel from lower drag from the alternator. When the ELD (electrical load detector) senses that the voltage is too low it allows the alternator to produce more. BUT while it should be instantaneous it really take a beat or two to catch up.
Perfectly normal operation for a modern Honda.
Old Apr 15, 2013 | 11:06 AM
when the a/c compressor runs my headlamps dim a little bit for a split second.
it's part of the car so doesnt bother me.
Old Apr 15, 2013 | 11:28 AM
DiamondStarMonsters's Avatar
Running all your accessories can take output voltage down a full volt.
I was playing with that the other day with the FlashPro. Radio, headlights/foglights/fan/compressor/defroster and the occasional rad fan flicking on and off could bring it from ~14.40-50 at warm idle to 13.30.
Easily enough to see the change in your headlights, and I would wager the dash too.
Old Apr 16, 2013 | 03:09 PM
Phantisy's Avatar
This is basically what the Honda dealer told me after having it in 2 times for the same issue. It is to save gas. I HATE it because I can see my lights dim while driving.
Old Apr 18, 2013 | 01:00 AM
Red 05's Avatar
I only notice a dim when I come to a complete stop, and only at night. I got used to it, doesnt bother me anymore.
Old Apr 18, 2013 | 01:54 AM
loudbang's Avatar
When you are at a full stop you are at idle and lowest output of the alternator.
Old Apr 20, 2013 | 12:43 PM
I wonder if this is why the battery on the fits always take a crap.
Old Apr 21, 2013 | 02:34 AM
loudbang's Avatar
The battery is made to be charged and discharged why would an EDL make a difference? Inquiring minds want to know.
Old Apr 21, 2013 | 07:37 PM
2012FitFan's Avatar
From Honda's FAQ on owner's website:
Is it normal for my headlights to dim slightly and then come back to normal while my car is stopped at a light?
This is a normal characteristic and is caused by variations in the electrical system created by the onboard computer. The computer controls the output of the electrical charging system to improve fuel economy and minimize vehicle vibration.
While the engine is at idle, the computer monitors the electrical usage of the car and then controls the electrical charging system so that it charges just enough to keep up with demand. This change reduces the load on the engine and, in turn, increases fuel economy and reduces vehicle vibration. As electrical accessories turn on and off, the computer changes the rate of electrical charge in response to the changes in demand for electricity. As the computer responds to the addition of electrical load, you may notice a momentary dimming of the lights. For example, the headlights or instrument panel lights may briefly dim as the air conditioning cycles on.
hogwylde
May 27, 2013 06:18 PM
N.O.R.M
Mar 31, 2013 12:23 AM
MTLian
Jan 15, 2013 02:32 PM
HondaFit4Fit
Jan 6, 2011 01:36 AM
ccaleb02
Nov 29, 2008 09:56 AM
