Vibration after install...
Old Aug 11, 2008 | 01:11 PM
garseeahh's Avatar
So lastnight I installed the t1r springs. The install went smoother then any other cars i lowered. The only thing that happened was the drivers side axel poped out... oops.. but other then that now when I am driving... anything after 30mph i get this heavy vibration like something is wrong.. I cut the bump stops a little but im not sure if i cut them enough... any other ideas yall think this could be from? Im clueless right now.. almost feeling a lil retarded because ive never had any problems like this before...
Chris
Old Aug 11, 2008 | 02:06 PM
sam21's Avatar
check the nuts on top of the tower bars again,ive had problems before when i forgot to tighten those down.
Old Aug 11, 2008 | 02:10 PM
doctordoom's Avatar
Supervillain
my guess is something is loose. i think the first and simplest thing to do right now is re-check that you torqued everything back tightly, including the wheels.
Old Aug 11, 2008 | 03:08 PM
Tofuman's Avatar
yes... do not forget to torque down wheel lug nuts. i had a friend that drove to work and forgot to torque down his lugs all the way. he made it to his work parking lot, but by then all of the lugs fell off and his wheel came off while he was driving in the parking lot. luckily no damage done. he just took 1 lug nut off the other 3 wheels to hold on his wheel until he got to the parts store to get more.
Old Aug 11, 2008 | 06:50 PM
garseeahh's Avatar
well i know its not the lug nuts cause ive had that experience when i was younger also... but errr i still havent went back out to mess with the car yet and see what it is.. maybe again later tonight... thanks for the suggestions..
Old Aug 11, 2008 | 08:38 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Dont blame my used springs!
From what I know garseeahh said it comes from the passenger side of the car.
He thinks it may be the wheels. I suggested rotating that tire to the rear. If the vibration follows at the rear than its the tire/wheel. But all this after a spring install doesnt make sense.
Im still calling the pass. side axle. Because it looks good doesnt mean internally its not F-worded.
Not sure if you popped that side back in place too, but maybe one of the joints popped?
BTW, hows the stance?
jaymoneypain
3rd Generation GK Specific Suspension & Brakes Sub-Forum
Jul 21, 2017 09:14 AM
stylzjhn
May 12, 2010 07:20 PM
JIBBZ2
Mar 14, 2009 10:20 AM
GD3_Wagoon
16
Jun 11, 2008 10:34 PM
angelberybblgum
Mar 25, 2007 06:00 PM
