No Pause?
No Pause?
Does anyone else find it odd there's no music pause unless you're listening to Bluetooth Audio or Pandora? The manual states:
At this point, I'm powering the unit off when I need silence. Am I missing something? Thanks!
Steering Wheel (Menu) Button
• When listening to the radio
Press : To display the menu items. You can select Scan, Save Preset, or Seek.
• When listening to a CD or USB flash drive
Press : To display the menu items. You can select Scan, Repeat, or Random.
• When listening to an iPod
Press : To display the menu items. You can select Repeat or Shuffle.
• When listening to a Bluetooth® Audio
Press : To display the menu items. You can select Pause or Play.
• When listening to a Pandora®*
Press : To display the menu items. You can select Bookmark, or Play/Pause.
i find it retarded there is no play pause button as well! and minutely aggravated that there is a mute button but you have to touch the volume button scrreen then hit it...so usuallly i just hold down the volume down steering wheel control
What is wrong with hitting power buton?
