how do i get the rear springs out?
Old Aug 30, 2008 | 08:30 PM
Tofuman's Avatar
i'm installing some lowering springs right now. the front is done. the instructions i used for the springs i found on here just says to remove the 14mm bolt and the spring will just come out. well, i got the bolt out, and the perch dropped like it's supposed to, but it doesn't seem like enough to get the spring out. i tried pulling down a little but nothing.
anyone help asap?
Old Aug 30, 2008 | 08:32 PM
SD_MR_FIT's Avatar
if you get the bolts out... the rear thing that holds both the springs should drop right out.
solbrothers's Avatar
is your tire off? have someone step on the lug studs and the rear torsion beam should drop and you can slip the spring out. going in should be much easier because the spring is physically shorter
Tofuman's Avatar
it dropped down, but the spring is still in there pretty snug.
Old Aug 30, 2008 | 08:33 PM
SD_MR_FIT's Avatar
pry the spring out i suppose. turn it and pull that thing out. muscles! heh
yes i forgot about that. yeah....step on the studs and push that thing down....
i remember doing that now.
Tofuman's Avatar
oh i see. so keeping the tire on will help pull down the perch... i see.
giving it another go.
Old Aug 30, 2008 | 08:34 PM
yeah. pull down on hte tire to unload the suspension. if the tire is off, have someone step on the lugs/brake assembly to lower it. the spirngs should come out after that..
Old Aug 30, 2008 | 10:11 PM
Fa1's Avatar
Fa1
It's due to the torsion beam setup. You need to jack up both sides and unbolt both sides at the same time. Then both springs should just fall out. Shouldn't need to pry them out or anything.
Old Aug 30, 2008 | 10:27 PM
+1 dont need to pry anything.
Old Aug 31, 2008 | 06:24 AM
doctordoom's Avatar
Supervillain
^agreed. don't force it.
Old Aug 31, 2008 | 08:34 AM
vtecdreamer's Avatar
Did you get the rear suspension on???
Old Aug 31, 2008 | 03:24 PM
Tofuman's Avatar
yup, i got it on! i'll post pics later. i took a lot of photos so i could create another DIY with more pics and details.
revd34
Jan 9, 2021 02:03 PM
Myxalplyx
Racing
24
May 22, 2015 02:36 PM
pig_pit
Apr 6, 2012 03:41 AM
AWDturbo
Oct 27, 2008 04:00 AM
prossett
Dec 9, 2007 10:40 PM
