Clutch Travel!!!
Old May 12, 2006 | 03:48 PM
gettinafit's Avatar
Clutch Travel!!!
This goes out to everyone who drives a 2007 5speed Fit i guess in the US!!
The clutch travel (on the way up), before reaching the 1/4 of an inch of engagement area, is like almost to the top!!
I thought that maybe it just needed to be broken in. Now i've got 1150miles on it and it's the same!
Is yours the same? or should i go back to dealer!
I have read an article describing, " the 5 speed clutch is like a feather, but the depression of 9 inches for 1/4 in of engagement felt lacking....."
Anyone in other markets (Europe, Asia, Auzzie) have this? Overcome this be some means?
Tks
Old May 12, 2006 | 10:02 PM
Chikubi's Avatar
For what it's worth, mine is the same. Just takes a bit of getting used to for smooth shifts, but it can be done.
Old May 12, 2006 | 11:27 PM
JDMGD3's Avatar
I dont even have 100 miles on mine yet and ive pretty much mastered it already. I got the hang of it the first time I test drove it, the salesman was shocked how quickly I adapted to the clutch cause he wasnt driving nowhere near as smooth as I was. Its not an issue for me, I have another car which is a MT as well but the clutch engagement isnt that close to being at the top of the travel as the Fit's.
Old May 12, 2006 | 11:43 PM
Meterman's Avatar
I think the clutch is hydraulic (so said my sales dude) so the engagement position should not change over the life of a clutch like a cable operated clutch will.
Old May 13, 2006 | 10:27 PM
dougiepants's Avatar
Avid FitFreak Poster
The rough feeling between shifts at lower rpm is do to the heavy flywheel... This continues the engine to briefly rev up and causes the rough or odd shifting feeling aswell...
Old May 14, 2006 | 05:04 AM
pokems23's Avatar
June 2007 3rd Place Fit of the Month Winner
I have roughly 1000 miles. Took a little to getting use to the clutch engagement. But pretty much got it down now.
Old May 14, 2006 | 10:48 AM
sillypuddy's Avatar
Someone that Posts too much
i had no issue with the clutch travel, but then i been driving manual cars for 16 years lol
-joe
Old May 15, 2006 | 09:57 AM
gettinafit's Avatar
I'm not saying that there is an issue necessarily, i was just wondering if it was normal!!
And to "claymore" thanks for the specs, As you can see, the full travel is 5.5 in and it engages 2.9 in most of the way towards the top!
The Fit happens to be in for service for a "we owe" item, the car came with a small dent on it they have to pay for and fIx! So i mentioned the clutch travel at the same time..
Lets see if they actually look at the specs! Because everyhonda i've driven before doesn't feel like the FIt's clutch, and if they don't research the specs they might think that there is something wrong As well!
We'll see! Thanks for confirming that it is normal, let's see what North Shore Honda on Long Island in New york thinks!
Old May 15, 2006 | 03:46 PM
Paulo107's Avatar
i feel that clutch is smoother at higher RPM shifts...it does catch good at hard higher RPM shifts
Old May 15, 2006 | 03:51 PM
Dañiel's Avatar
It's that over rev that takes time to get used to.
Old May 15, 2006 | 03:53 PM
Berto's Avatar
gettinafit
You can adjust the setting yourself more than likely. I don't have my fit yet but if its like most hydraulic systems its fairly easy to adjust.
look at the top of the clutch pedal where the master cylinder rod attaches to the pedal, there should be a codder pin through a rivet. if you pull the codder pin and rivet out and just "screw in" the part that attaches to the pedal it should set the engagement much lower.
It might sound lik a big task but if you have the slightest mechanical knowledge it should not be a problem just get down there and take a look.
This is what iknow from recenly doing my master cylinder replacement in my corolla.
Old May 16, 2006 | 09:54 AM
gettinafit's Avatar
Thanks guys,
When i get my FIT back from the dealership and they haven't already done it i will look into that myself!
Thanks much
Old May 16, 2006 | 04:08 PM
dacalac's Avatar
personally I like the high engagement point. I barely have to tap the clutch dwn unlike on my 240 where I had to press it down pretty far.
Old May 16, 2006 | 04:09 PM
sillypuddy's Avatar
by messing with the clutch travel, you might get it to the point where it's not fully disengaging the flywheel, and you will end up with premature wear and tear
-joe
Old May 16, 2006 | 11:14 PM
benfal2001's Avatar
If I fully press down the clutch while waiting at red light, does the clutch is wearing ?
Old May 17, 2006 | 12:22 AM
kz098123's Avatar
The clutch will not wear, but your throwout bearing will.
FullEffect256
Mar 6, 2019 02:52 AM
Bounce
Jul 15, 2017 07:28 PM
desertsp
Aug 20, 2016 06:06 PM
sean5995
Apr 12, 2012 08:41 AM
shy34
Aug 31, 2009 03:16 PM
