35W 50W HID whats the difference?
Old Oct 7, 2008 | 04:11 PM
pwnstar's Avatar
ok so i was looking dose anyone have pics or video on how much brighter 50w hid's are then 35w? is there even a difference? and if my HID fog lights dont hook up to the battery will thay not be as bright as ones that do? or will thay just take longer to charge up? lol i just put them in thay look pretty bright just have to wait till night and see.
Old Oct 23, 2008 | 12:35 PM
madhartigan's Avatar
bump for any possible replies.
I'm curious about this too.
I'd imagine the increased wattage provides greater brightness, but I don't want to believe in a fiction. So, if anyone has some decent facts to back up my assumption I'd appreciate it.
Thanks!!
Old Oct 23, 2008 | 12:38 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Its what common sense tells you. Theyre brighter.
More wattage means hotter too. More heat means less life. The place I get my HID's from has 50watt kits now, Ill stick with 35watt kits. Its plenty, and theyll last longer as they dont run as hot.
Old Oct 23, 2008 | 12:40 PM
Fit_to_be_tied's Avatar
i guess 15w brighter
Old Oct 23, 2008 | 01:10 PM
Will I Am fit.'s Avatar
Formerly "bitoy"
It's definitely brighter than 35w you will notice the difference but still not as hot as the stock halogen bulb, remember that the stock halogen bulb run on a 55W low and 60W high. If you are to use the 50W HID I would say it would be best to use it in a projector headlight not the reflector ones that we have in our car due to more glare that it produces as compared to the 35W HID bulb I mean a lot more glare....
edit: I did have a 50W hid in my retrofit
Old Oct 23, 2008 | 05:52 PM
Posts in the NUUDE
Am I one of the only Fits that have almost NO glare? I really think its due to my flat black headlights. The glossy OEM housings cause a reflector all over causing a bunch of glare.
Id still suggest the 35watt kit. Are there any can manufactures using the 50watt kits?
Im sure there isnt.
Old Oct 23, 2008 | 06:26 PM
Formerly "bitoy"
Im sure there isnt.
I don't think there is a car manufacturer the makes the 50W HID even putting it in a projector, the 35W is more than enough to light up the street. It's only the aftermarket manufacturer of HID are making them IMO it's useless having that much of wattage on an HID unless you use it for offroad.
Old Oct 23, 2008 | 06:36 PM
JDMxGE8's Avatar
HID kits usually operate at 35W.
Old Oct 23, 2008 | 10:23 PM
FitVic's Avatar
i got flatblack housing But yeah I have 35w and shortly after the 55w kits started to show up. To me 35w is good enough. I've seen a 55w 9006 HID in action and its brighter compared to my 35w but I'm a nice guy. I'll let the otherside of the street see where they are driving lmao
dustin_said_hi
35
Sep 27, 2018 10:52 AM
DannyBoy8
Mar 8, 2013 01:33 AM
solbrothers
110
Apr 26, 2012 07:07 PM
tanger
18
Mar 2, 2009 07:39 PM
sonicsc1
Dec 7, 2007 04:13 PM
