lowering spring/camber kits/shocks
Old Oct 11, 2008 | 02:50 PM
jadie's Avatar
hi everyone,i'm planning to get some lowering springs and i just want to know if i need any camber kits or anything. Also can i just do springs with stocks shocks?
Old Oct 11, 2008 | 04:00 PM
Will I Am fit.'s Avatar
Formerly "bitoy"
yes you can use the stock shock most of the people do. as for cambers I did use camber bolts on mine coz I didn't want my tires to be worn out quickly and did some alignment but I hear some people didn't have to.
Old Oct 11, 2008 | 08:43 PM
cojaro's Avatar
Lowering springs with stock shocks will shorten the life of the shocks.
Also, get an alignment after you lower your car. The toe will probably be outa whack. It's best, though not necessary, to get camber bolts. You can feel a difference with the right camber angles on the stock suspension alone.
Old Oct 12, 2008 | 01:55 AM
its.ryu's Avatar
Hey Jadie Like everyone said you can run lowering springs with stock shocks, its what most people are doing right now. That is what I am running on right now, until I pick up my coilovers this week. Camber bolts are not required but it will help depending on how low the drop is.
Old Oct 12, 2008 | 12:57 PM
jadie's Avatar
hi, did you get camber bolts for your setup? what kind of springs are you on?
Old Oct 12, 2008 | 05:30 PM
its.ryu's Avatar
I am on Tanabe DF210s with stock shocks, I have camber bolts from SPC but not installed. I will probably install them when I install my coilovers.
Old Oct 17, 2008 | 12:56 AM
SecSpyral's Avatar
can we expand on this topic? What camber bolts did you buy?
Old Oct 17, 2008 | 01:14 AM
Slimjimx701x's Avatar
I got mines here Honda 2007 Fit SPC Performance Camber Kits
There petty good....still need to install the shims. FYI I'm at -1.5 camber and 0 toe at front....but for rears, it's stock (-1.5 left, -2 right -_-)
Old Oct 17, 2008 | 11:28 AM
SecSpyral's Avatar
thank you
jhn
3rd Generation GK Specific Suspension & Brakes Sub-Forum
20
Dec 26, 2018 07:14 PM
whitefitsport
Oct 2, 2018 10:54 PM
MyooLah
Nov 29, 2017 04:20 AM
SickFit
29
Sep 28, 2012 12:00 PM
FELIXY69
Jul 21, 2009 10:38 AM
