Rotors (Blanks) - OEM or aftermarket?
Old Nov 10, 2008 | 09:31 PM
p1driftfiend's Avatar
Question Rotors (Blanks) - OEM or aftermarket?
I've been getting quite a wobble/shimmy from high-speed braking (60-50 down to dead stop) and I've decided that it's time to give the rotors some attention.
My pads are still original, and look every bit as thick as they did the day the car rolled off the lot back in '06.
I assume that the rotors could use turning, but since dealers and shops charge at least $45 (all the way up to $160 for resurfacing!), I figure I'll just buy some new rotors.
I'm not looking for any crazy slotted/drilled rotors, just plain blank rotors.
Any recommendations? Aftermarket blank rotors from Pepboys/Advanced Auto/Autozone are considerably cheaper than OEM rotors from dealers. Any advantages between the two?
Old Nov 10, 2008 | 10:02 PM
hazzard's Avatar
I know the dealer wants 100cdn a piece and brembo want the same. I am in the same boat my brake have been doing this for a while ( it is about 100cdn to get both turned )
Old Nov 11, 2008 | 12:25 AM
enjoito's Avatar
hmm u can get regular blank rotors and just upgrade your pads then its all g!
i had brembo replacement rotors and hawk pads on my civic it was the best street setup just needed to upgrade my lines..
just remember slotted rotors eats the break pads a bit faster but u break faster.
Old Nov 11, 2008 | 12:39 AM
Super Mario's Avatar
I'm considering this also, when the time comes for me to resurface my rotors. I'm probably going to replace them with Brembo Blanks
EBC makes okay brake products. Here's some crazy looking rotors EBC ROTORS.
Old Nov 11, 2008 | 12:40 AM
Were you on Civicforum.com formerly 7thgencivic.com formerly 2k1Civic.com? Did you have an EM2?
Old Nov 11, 2008 | 05:31 PM
Thanks so much for the link! I gave up searching for Brembo blanks - thought they weren't made for the Fit.
Still a little pricey compared to other blanks, wonder if they are worth the extra bucks...decisions, decisons...
Old Nov 11, 2008 | 06:16 PM
trancedsailor's Avatar
tagged for future reference. Mine give me a vibration BS when I brake and I only have 4800mi but I live on the ocean.
Old Nov 11, 2008 | 06:30 PM
JDMxGE8's Avatar
I'd get some slotted rotors.
Old Nov 20, 2008 | 03:45 AM
richard612's Avatar
I've been running a pair of $20 Kragen rotors for a little while. They've been fine so far. Tonight I had them hot enough to get some brake-pad stink, still no sign of trouble.
If you guys are having ongoing brake pulsing trouble, you might need to modify your driving habits a bit and possibly switch to a pad that can handle higher temps. Iron carbide deposits (cementite) will damage a set of Brembos just as fast as a set of stockers.
Old Nov 20, 2008 | 08:35 PM
Fit_Dr's Avatar
A lot of people have trouble with brake shudder on the 1st gen Fit. Mine appeared around 18K mi and the dealer resurfaced the rotors for me which corrected it. That said, I drive aggressively enough where I didn't want to keep having this probem. The Fit's brakes brakes are pretty good stock, but I've ordered Brembo slotted rotors and Porterfield R4-S pads.
Old Nov 26, 2008 | 11:57 PM
jman245's Avatar
i had the same wobble problem and took it to the dealer and they re-surfaced them for free!i was even pass the warranty of one year 12k miles
Old Nov 27, 2008 | 09:23 AM
mahout's Avatar
The best advice you can get is not to buy the cheapies from the car parts places. Most are from China and are as low grade as you can imagine. Stick with the recognized brands>: Brembo, StopTech, Hawk, or acknowledged sellers like TireRack.
While you're at it upgrade your pads too.
Old Nov 27, 2008 | 09:55 AM
1coolride's Avatar
aftermarket rotora rotors are pretty good. the slotted ones are nice. but i'm gonna buy a big brake kit. either spoon, brembo, or rotora.
Old Nov 27, 2008 | 11:02 AM
Carbuff2's Avatar
All Hondas are prone to brake shudder. This is a hot topic across all the Forums I belong to.
A big factor is uneven torque on the lug nuts.
I ALWAYS use a torque wrench. I also retorque immediately after a shop has touched my wheels.... If the wheels heat up with overtightened lugs they can warp!
Result? 150K miles on the OE rotors of my Acura!
PS Coating the contact surface of the wheels & hubs with anti-sieze paste aids in the transfer of heat during braking....the wheels act as a heat-sink for the brakes.
Old Dec 7, 2008 | 10:51 AM
SaM01's Avatar
Does all Fit or Jazz use the Same rotors ?!
I have a 03 Jazz, Base model... Does the rotors change for the 07/08 Fit ?! or are they the same ?! Plus ive heard that some rotors that fit the old civic work better on the jazz ?! is this true ? Which civic is it !?
Any help ?!
Thank You
SaM
Tinn-Can
Feb 2, 2018 11:28 AM
TaubBaer
Jun 1, 2017 12:11 PM
pmartensen
Jan 11, 2013 06:08 PM
Eugene.Atget
Oct 21, 2011 12:33 AM
slip
18
Jun 19, 2008 11:10 PM
