Anyone familiar with Compustar 2W8000FM-A alarm?
Old Nov 16, 2008 | 10:06 PM
tanger's Avatar
I was wondering who has the same thing? Is there any way to adjust the shock sensor on the remote to make it more sensitive? I could rock the car side to side and nothing would happen...
Any special effects or cool things that aren't listed in the manual? Thanks!
Old Nov 21, 2008 | 11:29 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
yes your shock sensor should have an adjustment right on it.
i believe it's on the top oposite the wire plug.
you would just tap my old car and it would chirp.
also on the two way remote you can change the auto lock on or off.
basically arming itself.
Old Nov 24, 2008 | 04:34 AM
tanger's Avatar
Where's this wire plug thing? Is it the thing inside my car or under the hood where i adjust?
Old Nov 24, 2008 | 03:06 PM
niko3257's Avatar
99% of the time they zip tie it to your steering
column. look under your steering wheels and you will see
all the wires and such.
Old Nov 25, 2008 | 09:56 PM
tanger's Avatar
Thanks! I found it and was able to turn the dial higher...unfortunately, it doesn't do anything. The shock sensor symbol is not showing on the remote (which means it's on right?). Any reason why it doesn't work?
Old Nov 26, 2008 | 11:01 AM
niko3257's Avatar
you must have muted it or put it in valet mode
accidentaly.
do you have a owners manual?
or even look at the back of your remote
it should tell you how to do it.
i think it's button two and three push together.
but i'm not 100% sure of that. i haven't used the
system in over 3 months.
right now it's sitting on the shelf in the garage.
trying to deciede to put it in or not.
Adamrmusic
Apr 18, 2019 09:40 PM
alegr44
Dec 27, 2017 07:01 PM
intiaz_k
Dec 30, 2014 04:06 PM
Starscream
Nov 29, 2012 01:26 AM
cph81
Feb 21, 2008 07:48 PM
