mFactory 4.7FD/Quaife ATB LSD/T1R clutch installed!
Old Nov 27, 2008 | 12:30 AM
spoonek4's Avatar
What a goooooooooooood difference these stuff make!!!!!!!
My brother started to remove & disassemble my Fit's transmission last Friday to install the final gear, LSD & clutch set. We have 90% of the tranny Re & I shop manual print out with us that day. Which made the job quite a bit easier for us. I did get two brand new differential carrier bearings & all the shims that are listed in the manual. Finally, the Fit transmission(code#G4A) is out & ready to be disassembled.....
Stupid OEM open differential & stock final gear is out of the transmission:
Stock 4.3 final gear!
Here's the brand new Quaife ATB LSD with mFactory 4.7 final gear. Now look at the black gear on top of the LSD which sits right between the top differential bearing & the diff assy. That's your Fit's vehicle speed sensor(VSS). Now the problem is, if u don't have the proper tool to help pulling or press the bearing out, like a bearing seperator, and u don't have a brand new VSS sitting there like me. Then u're risking to break it, coz it's made with PLASTICCCCC! We got lucky to pull that mofo bearing out without breaking the VSS thank god, although that took us quite a bit of time.
Anyway, he sent my flywheel out to get it machined & finish up the rest of the LSD, final gear, & clutch installation the day after while I'm at work.
Here's the stock flywheel before it get machined:
Stock clutch, which is made by AP! Whoa.......
Although I am still driving it very lightly for about 1000km & "run-in" the clutch & the gears, I can feel a pretty good difference from the new setup already. I was going uphill with my parents & my brother in my car, which I needed to use 3rd gear before if I don't carry enough speed(speeding). Now I can use partial throttle 4th gear with 4 people in my car without worrying too much about the car bogging/hesitates.
For the T1R sport clutch, I bought the set with organic disc from A&J Racing. Pedal feel is LIGHTER than a 06 Impreza STi & most of the ACT HDSS clutches for Civic/Integra. Response is much faster than the stock clutch & grips VERY WELL=NO SLIPPAGE so far. Engage point is even more consistant than the other set of Exedy organic clutch that I used before. After I passed 1000km I will make sure I do some harder runs & see how it works out.
And the Quaife LSD, I noticed less understeer with that installed and I think it grips harder than the stock ITR LSD that I used before. Nothing beats the feeling of both the front wheels keep pulling my car out of the corner. It really worth the time I spent to locate this LSD & get it all the way from UK!!!
Can't f**king wait til the next lapping season!
Old Nov 27, 2008 | 12:39 AM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
sounds amazing!
can't wait till the break in point so you can really play with it
Old Nov 27, 2008 | 12:42 AM
kylerwho's Avatar
spoon fed
congrats on the nex upgrade. im thinking soon i will need to go get the mfactory lsd cause i hate one wheel breaking loose as im exiting a corner. + rep for dyi
Old Nov 27, 2008 | 01:03 AM
spoonek4's Avatar
Yeah biiiiiiiiiiiiggggg thanks to my brother & of coz his friends for all the hard work, and also RagingAngel @teamMfactory.com and Ben @aj-racing.com for great service & technical support!!!!!
kylerwho: Yeah definitely get the mFactory LSD while the website is still showing the pre-order price. It's gonna worth the time & $ u put into it!
Old Nov 27, 2008 | 01:23 AM
kylerwho's Avatar
spoon fed
i have been chatting with them about it. im rather close so they can do it all in house for me.
Old Nov 27, 2008 | 01:40 AM
spoonek4's Avatar
I thought about doing that too actually. But there's too much hassle going over the border with all these parts. Might as well just do it here.
Old Nov 27, 2008 | 01:46 AM
kelsodeez's Avatar
UNBANABLE
thanks for posting this. i am going to be installing my mfactory lsd, exedy stage2 clutch and a fidanza flywheel. its nice to be able to see everything taken apart before i get in there. i need a service manual badly!
oh, also. why didnt you go with the exedy stage2 clutch??
Old Nov 27, 2008 | 02:15 AM
spoonek4's Avatar
U're very welcome. I didn't go with the stage2 because I'm still running a stock engine. The stage1 right now is more than enough for that 80-85whp on my car. Plus I drive at least 30km to & from work everyday in the traffic. Something too hardcore doesn't do me any good.
Old Nov 27, 2008 | 01:07 PM
FitFlowjoe's Avatar
DUDE Major respect with your car!!!!!!!
I have been paying alot of attention to you car because we both seem to be doing the samething with the Auto X in mind and not the super go crazy with the Hp.
One question at what rpm is your car now at 75mph in 5th gear?? Because that was my main concern with the lower final ratio... I know the car run high rpm as is..
Oh and I saw the video of you at your last auto cross... MaYoR ReSpEcT!!!! do you still plan to race STS class SCCA ?? now that you have a LSD .. or is that gonna be keep on the down low
Old Nov 27, 2008 | 01:09 PM
JDMxGE8's Avatar
Nice upgrades!
Old Nov 27, 2008 | 07:27 PM
doctordoom's Avatar
Supervillain
wow nice work! please post vids of your next session!
Old Nov 27, 2008 | 07:48 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Dang.. thats a lot of work. Ive ripped my Mazdas trans apart to change out the diff once. Wasnt too bad.
Guessing the Fit would be easier...
Id like some vids too.
Old Nov 27, 2008 | 07:54 PM
spoonek4's Avatar
Thanks a lot for the kind words guys!
Fitflowjoe: I will check the 75mph rpm reading for u tonight when I go drive more on my car. I think before I got the tranny work done my car was in SP or SM already. If I'm gonna autocross again next season I will put it into a proper class for sure, no point to hide it from anyone.
doctordoom: Yeah I will post up some more driving video later on showing speed range of different gears & rpm range first I think.
One more thing I'm gonna look into will be the fuel consumption. But so far dont think it got any worse than before.
Old Nov 28, 2008 | 01:14 AM
RagingAngel's Avatar
Click here for the comparison between stock (blue) and MFactory 4.7 (red)
MFactory Competition Products - THE Replacement for Displacement!
Thanks for doing the comparo Jackie! I'm looking forward to the videos as well. Hopefully this will go to show just how important gearing truly is!
Old Nov 28, 2008 | 01:56 AM
spoonek4's Avatar
Yeah but I really wanted these items that's why I don't care how much hassle I need to go through I still wanna get it done.
Gotta put as much power to the ground as possible.......
Old Nov 28, 2008 | 02:08 AM
kylerwho's Avatar
spoon fed
what about the mfactory gear kit? any intrest in this spoonek4?
Old Nov 28, 2008 | 04:32 AM
spoonek4's Avatar
U meant the 3/4/5 cross gear set? I was talking to RagingAngel about it & I decided to go for final gear set after all. Coz I want 1st & 2nd gear to make a difference too.
I just had a drive around town & rpm at 75mph is around 3600rpm with my 185/65R14 snow tires.
Old Nov 28, 2008 | 02:11 PM
kylerwho's Avatar
spoon fed
what is your rpm at 60mph? its to bad about having to change the whole main shaft to get a new 1st and 2nd gear. i think those two gears would be nice if they were taller.
Old Nov 28, 2008 | 09:33 PM
Change the tire size accordingly to suit your car.
Does everybody just glaze over the fact that there are tools like this readily available?
Old Nov 28, 2008 | 10:10 PM
kylerwho's Avatar
spoon fed
i guess i missed that somewhere. thank you for showing me. + rep
