Tell Me How --- > Washer Bottle :) !!!
Old Feb 3, 2009 | 12:42 PM
FELIXY69's Avatar
when FI u have to remove washer bottle
my first thought was .. its ok...i get to save weight !!
but winter times, it is a must to have it so you can see properly through the windows....
i need to put it back....
i've seen some of you guys have it relocated...
but how do you fit the bottle neck ? and where ?
PLEASE POST PIC !
thanks in advance !
Old Feb 3, 2009 | 12:50 PM
dewthedew's Avatar
god that sucks.. does the hks kit require you to remove it?
Old Feb 3, 2009 | 01:04 PM
NIGHTHAWKSI's Avatar
i am going to cut the neck off the bottle at a point where it will be about a 1" diameter hole. then get 1" diameter clear plumbing hose from home depot/lowes. inset it a bout an inch into the new hole at the top of the bottle. and use silicone to fill in the gap and seal it.
route the hose under the headlight, up behind in through the fender and into the engine bay near the brake lines.
i havent thought of a cap for it yet though.
Old Feb 3, 2009 | 03:53 PM
FELIXY69's Avatar
post pic when u are at it!!
i wonder if there are any flexible tubes i can use for me to route it around tight corners....i was thinking about using soft PVC pipings...
but for sure you need JDM washer bottle firsT !
Old Feb 8, 2009 | 05:16 PM
YeeFit's Avatar
Hey Felix69.
I got the JDM washer bottle with the T1R kit. I had to custom fabricate a mount for the smaller bottle and extend the filler spout.
I used a clear tubing that I picked up from Home Depot and that hose is fairly flexible. I mounted the smaller bottle in the same location as the stock one, I just had to make a couple brackets. You won't be able to use the fluid level sensor in the JDM bottle tho, but thats not a big issue, just that the light won't even come on that your low.. you'll just run out.
Mine works great now, no leaks or anything... It's definitely a must have for anyone living in an area that snows/rains in the winter months. I just took these pics, I don't have any of the bottle with the brackets I made tho. But this should give you an idea and confidence to get'er done
Old Feb 8, 2009 | 05:19 PM
YeeFit's Avatar
Yup, you can't retain the washer bottle with the HKS kit. You'll have to make something work.
Old Feb 8, 2009 | 05:25 PM
wdb's Avatar
wdb
Just use the other end of the neck, the part you cut off. (See pics above of someone else's similar fix.)
I'm impressed with the innovativeness of the forced induction folks here!
Old Feb 8, 2009 | 05:29 PM
YeeFit's Avatar
You don't actually have to cut the filler tube off of the bottle, it just pops off!
If you look very closely at the second pic there is still a rubber O-ring on the filler neck from where it was plugged into the reservoir... it wasn't too difficult to do, the hardest part was making the brackets to mount the smaller bottle.. I think maybe 2hrs from start to finish
Old Feb 8, 2009 | 09:50 PM
FELIXY69's Avatar
Thx so much
tho another problem I will have is I have no where to mount the bottle
I had to cut the intercooler pipes and make it shorter so I can mounts the intercooler right up against the rad so that it will clear the front bumper with cutting every thing out
I'll see if I can fit it tho !! Cuz a washer bottle is just a must
Old Feb 8, 2009 | 11:43 PM
YeeFit's Avatar
Originally Posted by FELIXY69
Thx so much
There should still be some room in the front area where the OEM bottle was... but I guess its hard to say.. maybe relolate your battery and put the bottle there?
You have the JDM front end conversion right? I think it'll be a tad more difficult.. but i'm sure you'll find a way.
GL!
Old Feb 10, 2009 | 01:20 AM
explosivpotato's Avatar
Wow you guys put a lot of thought into this.. Kudos!
Mine's strapped in with bungee cord. The filler is cobbled together with duct tape and garden hose. Looks ok, actually, and it WORKS! Woohoo for Michigan Redneck engineering!
Old Apr 3, 2009 | 06:17 PM
FELIXY69's Avatar
back to the Washer bottle solution
here is the mock up version of how i am gonna extend it...
Parts are from Home-depot
2 pvc tubes + Hose clamps + Glue gun
this is the part where i need to use glue gun..cuz it isn't tight....
Old Apr 4, 2009 | 05:49 AM
azkikersfit's Avatar
dats is nicely done Felix! good job on dat water bottle!
nice! very nice
texas_fit
Oct 16, 2016 08:00 PM
TomFit
Aug 7, 2016 10:09 AM
kbonus
Dec 8, 2014 02:05 PM
bdogpot
Nov 27, 2012 09:31 AM
eat2na
Aug 28, 2008 09:51 AM
