What do you use to clean windshield grime?
Cheers
+1 for Stoners Invisible Glass works great on tint and the windshield too. I started using it when both my wife and I smoked and it was the only thing I found that got the tar off the inside of the windows.
I have a can of Eagle One window cleaner spray that I use with blue shop towels. Works well enough. Or I use a clean white terry cloth towel. The terry cloth and cleaner seem to do an excellent job.
Armor All glass cleaner, applied with old newspapers. Apparently the newspaper is abrasive enough to have a polishing effect. It's worked well for me so far, inside and out It's also good for removing adhesive from old stickers.
One just has to be careful with the drying and diligent with the wiping. Excess amounts of Armor All glass cleaner that aren't wiped off properly leave a slightly hazy residue.
for windows i use Prima Clarity or Griot's WindowCleaner which ever
i have in stock at the time.
for SUPER OILY CRAPPOLA windows on the outside, i first use RainX to
dissolve the crap on the glass (mostly oils and grime) followed by
a mist of distilled water and dry glass MF towel to remove.
use dedicated glass MF towels, not paper towels.
littleblackcar
09-02-2014 12:07 PM
