Headlight bulbs, Changing them and other questions
Old Jun 11, 2006 | 11:51 AM
dougiepants's Avatar
Avid FitFreak Poster
HID & then Sylvania
Old Jun 11, 2006 | 12:12 PM
LiL Wee FIT's Avatar
IMO.....
For light output:
Philips Vision Plus or Orsam Silverstars
For looks:
Luminics and Nokya looks pretty good to me....
So you have to decide for yourself if you want function or looks.
As for HID's... Im actually running a set right now, and the glare is just terrible! Also, with HID's, you basically lose your highbeams and DRL (if you have it)
-Sherman
Old Jun 11, 2006 | 01:11 PM
aziatiklover's Avatar
Master FitFreaker
I would say go straight up with HIDs
Old Jun 11, 2006 | 08:12 PM
els2023's Avatar
Which lasts the longest: PIAA, Sylvania, or Philips?
I am just about to buy the PIAA because it is a company I have heard of but does anyone know Which lasts the longest: PIAA, Sylvania, or Philips?
Is H4 the correct bulb to buy to replace the Fit's headlight that functions as a low and high beam?
THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jun 11, 2006 | 08:16 PM
HFit USA's Avatar
Frequent FitFreak Poster
i bought some luminic bulbs and i have to say eh not bad....for hid loook.... and also ordered the fog light bulbs in the "jdm yellow"....looks really nice
Old Jun 11, 2006 | 10:15 PM
fitjunkie's Avatar
I got the PIAA GTX bulbs with purple-ish tints...made a great difference in looks and output...very close to HID, I retrofitted HID before, and I strongly suggest not to get the HID kits, as they will glare too much and the lights are ouput to the side and top, down...just leaks everywhere and looks terrible, save your money for a real HID retrofit...
Old Jun 11, 2006 | 10:23 PM
ludexr's Avatar
Bulbs vs. HID kit - price range
Bulbs Head light (H4) & fog lights (H11) spending about $150 or less.
HID system (H4 dual beam, made in Japan kit cost $399) + HID for fog light
(H11 single beam kit $299)
Members how much would you want to spend on lighting upgrade?
Old Jun 11, 2006 | 10:28 PM
blackgd3's Avatar
Senior Member
I have the polarg super yellow bulbs. I have to say, visibility is excellent!! It also looks really nice outside.
Old Jun 11, 2006 | 10:51 PM
michaelfit84's Avatar
ive got yellow nokya yellow foglight bulbs and they look awsome.....i was thinkin about yellow headlight bulbs but they are illegal
Old Jun 11, 2006 | 11:00 PM
Wave's Avatar
Exclamation
- For halogen bulbs I would have to say Philips Vision Plus.
- HID upgrades are nice and while not perfect like a "true HID system" it still outblasts anything that halogen can offer.
I went with a 4300K for my headlights and 3000K for my foglights that Roger@IK.com is selling in his group buy:
https://www.fitfreak.net/forums/trash-can/5834-import-kustomz-1-time-offer-hid-sale.html
Old Jun 12, 2006 | 11:14 AM
kps's Avatar
kps
Honda Fit Forums Moderator
If you want to see, read http://www.danielsternlighting.com/tech/tech.html (plus http://dmses.dot.gov/docimages/pdf82/176157_web.pdf for the technically literate).
If you're trying to impress 13-year-old boys (your personal life is none of my business), read http://www.danielsternlighting.com/tech/tech.html and do the opposite.
Old Jun 20, 2006 | 02:47 AM
  #32
akrams's Avatar
changing head light bulbs
when u change the bulbs to more powerful brighter ones does the headlight plastic casing get discoloured?
Old Jun 20, 2006 | 08:31 AM
  #33
spider2k's Avatar
when you replace your halogen bulbs with brighter bulbs they are usually almost twice the normal wattage. this means twice the current draw and significantly more heat. you run the risk of melting the factory wiring harness if you put a 100 watt bulb in a socket that has wires guaged for 55 watts.
ive replaced many a melted plug/harness at work due to people just buying 100 watt bulbs thinking they will do the trick and not knowing whats really going to happen.
if you choose to stick with halogen bulbs then get something thats the proper wattage. either that or just pick up a set of HID's .
Old Jun 20, 2006 | 08:41 AM
  #34
fad3r's Avatar
Daniel Sterns knows his $hit! I bought a pair of Osram SilverStars off eBay and they are 5x better than the American Sylvania junk you buy at Pep Boys.
Old Jun 20, 2006 | 08:43 AM
  #35
Wave's Avatar
For Halogen Bulbs I still love Philips Vision Plus.
Old Jun 20, 2006 | 12:48 PM
  #36
buttahball's Avatar
HIDz
I just ordered some HIDZ, they should be here next week I'll post pix
Old Jun 20, 2006 | 08:51 PM
  #37
FikseRxSeven's Avatar
according to daniel stern, you can get better light output (almost double) from the fog lights by replacing the h11's with h9. h11 are 35w and h9 are 65w
im curious if anyone here in the forum has tried 100/90w h4 bulbs?
and for the people that have used HID's, what brand did you go with?
Old Jun 20, 2006 | 09:41 PM
  #38
buttahball's Avatar
H9 bulbs vs. H11
this is what i've heard also, but the stock H11's on hondas are not 35W, they're 55W, so I'm not sure if its
worth the money and trouble to upgrade to another 10Watts, but hey 15% increase is noticeable
as far as 100 watt H4 bulbs go, they work great, however...that's a lot of heat o.O
Just make sure that you don't melt anything hehe
Old Jun 20, 2006 | 10:03 PM
  #39
i was mistaken... im sorry, typing too fast. i meant 55 not 35
55w h11 bulb produces 1350 lumens (per rallylights.com)
65w h9 bulb produces 2100 lumens
not bad for a 10w difference huh?
retrofitted hid at 4300k should be 3200 lumens
Old Jun 21, 2006 | 10:25 AM
  #40
buttahball's Avatar
dangs 2100 lumens isn't bad at all...it's prolly cuz the type/shape of bulb....
I think I will look into this more now
