Rally Car Ground clearance?
Old Apr 4, 2009 | 05:22 PM
runbikerun's Avatar
Hey, Anybody know off hand what kind of ground clearance is needed for an average rally car? I've never seen one up close.
Old Apr 4, 2009 | 06:22 PM
Super Mario's Avatar
Probably depends. 100% tarmac would be pretty low on some low profile tires. Dirt would be higher with small wheels and fat tires.
Old Apr 8, 2009 | 02:10 AM
it's pronounced iVTEC's Avatar
depends what you're running, smooth gravel roads usually you'll run about 5 or 6 inches, but rough and rutted roads you want to run 6+, it all depends on the conditions. i run between 5 and 7 inches on my car, but i mostly run heavy gravel roads that get a lot of ruts
Old Apr 8, 2009 | 01:26 PM
runbikerun's Avatar
Do you have any spring recomendations for the Fit to improve handling but also keep the ground clearance?
Old Apr 8, 2009 | 01:44 PM
tofu4's Avatar
hmm... i think you'd need coilovers for height adjustability in the long run. when conditions change you'd have to change the height to accomodate.
Tein Basic coilovers do just that (only height adjustable, set dampening rates).
Old Apr 8, 2009 | 05:49 PM
well if you're planning on running your fit in a rally, don't lol. but i'm using these on my civic TEIN USA | PRODUCTS | GRAVEL&G.TECH i had to modify the control arm a bit but it works perfect
panda1314
36
Sep 10, 2021 12:33 AM
ouchxx
Sep 27, 2011 06:01 AM
Lek
Jun 8, 2010 07:50 PM
revd34
Apr 29, 2008 03:20 PM
RyanR
Jun 11, 2007 05:26 PM
