Scoop Intake Build
Old May 7, 2009 | 10:32 AM
  #41
nxtfit_08's Avatar
thats cool ive just been waiting for somthing like this to come out for a while and if people buy the password jdm intake i think people would be willing to move it
Old May 7, 2009 | 12:36 PM
  #42
Rogue Fit's Avatar
Nice to see the continued progress, still looking good.
In building the air box I might suggest trying to find a plastic container that you can cut the side or bottom off of for the top of your box. If you could find something about the right size, it will probably already have nice radius on the sides and being that most are made from polyethylene or polypropylene, you can use the plastic as a mold for fiberglass. Since there are so may different plastic container out there, this may make shaping the box a little easier.
Old May 11, 2009 | 02:28 AM
  #43
Slimjimx701x's Avatar
Old May 11, 2009 | 02:36 AM
  #44
keepitpg's Avatar
i love college
cant wait for the final product!
Old May 11, 2009 | 01:30 PM
  #45
nxtfit_08's Avatar
for reall this is going to be nice
Old May 11, 2009 | 09:16 PM
  #46
Thanks guys
started to trim those wood pieces down to specs
NOTE: I need to invest in some powertools...the good all hacksaw and filer can only do so much (within reasons )
After that I started shaping and gluing down the pieces into the airbox
close up on my horrible job and cutting and gluing
MOAR support
Starting to dry
size comparison with my airbox
almost.....
making sure the glue is tight
AND AFTER FIVE HOURS, we got a chappy wooden box
pre-marked to fit the inlet of the filter.
Old May 19, 2009 | 02:27 AM
  #47
Sorry for the slow reply, I need to reformat my computer.
Been playing around with the idea of reshaping the box....
Triming for a better design my friend help me on (will take photo soon)
centering the mockup filter (I think I misread the specs...will check again...3in backplate/5inch height)
Since I'm petty depended on the Apexi filter being in my hands, I'll hold on working on the box. So back to the scoop....
Forgot to get the more updated photos
THERE ALOT MORE OF THAT
Old May 19, 2009 | 04:32 AM
  #48
petwhookie's Avatar
nice!
i got an aem filter if you want to try different filters
Old May 19, 2009 | 08:48 PM
  #49
Originally Posted by petwhookie
nice!
Sure. Where and went you want to meet up? Just wondering do you have the size for it as well?
Thanks.
Old May 20, 2009 | 12:49 AM
  #50
Updates
Starting to test fit the airbox plus filter combo....
My test filter does not fit anymore
New test filter made (3 inch diameter backplate and 5 inch height)
Size comparison...from left to right. 3inch Apexi, 5inch (gut feeling that the 3inch Apexi is almost too small) and the 6.5inch test filter (if i remember )
3 inch filter
Now with the 5 inch filter
test fitting of the "battery tray adapter"
it's the same size of the battery
fits just nicely
a little shorter of than that stupid baffer of the OEM intake
about 5 inches
reworking of the scoop
FINALLY a nice cruve
test fitting of the scoop, look just right
soon going to primer the scoop to make it a bit stronger so I can work the "duct" without worrying about messing up the nice cruve. Then Bondo the rest to flow better with the whole car.
Old May 22, 2009 | 06:21 PM
  #51
joggriffin's Avatar
Nice work. I love the revised scoop shape. it looks like it should flow like mad with that straight shot to the throttle body.
Old May 24, 2009 | 12:23 PM
  #52
Thanks alot, that scoop design is not done yet. It going to be primer and than "bondo-ed" to the cowl so we do not have that hump thing. But under the primer stage....the scoop melted...SO back to the scoop agian , it should be easier now since I made about 4 of them by now LOL.
IMO I think my airbox look too plain... maybe if I just round out the edge and add that plate, it might look better, but we'll see.
Old May 28, 2009 | 01:32 AM
  #53
It been awhile since I updated...
MELTED from primer...
remade with the foam from very beginning of the build
with 7layers of primer to prevent it from warping
test fitting...look petty good ...going to add some bondo to make the scoop more integrated with the cowl
getting ready to make the scoop itself
Sorry I forgot to take pics after "re-primer-ing"
EDIT: I forgot to mention, I ordered my Apexi filter yesterday
Old May 28, 2009 | 03:29 AM
  #54
petwhookie's Avatar
Thanks.
no idea about the sizee
Old Jun 7, 2009 | 12:22 AM
  #55
Updates...
cleaned "scoop"
Tried out bondo, but made the job ALOT harder...it seems that I don't have much control on it (at least for me)
prep work, so I can still pull everything apart later....
HELL
prep work for modeling clay...easier to work with
first 30mins
first hours, before I realize that I could a hair-drier
one more hour....
Now need sanding to smooth everything up, and open the hole up abit...the opening is just a MM below the hood....about a CM more should do it.
Old Jun 7, 2009 | 02:07 AM
  #56
nxtfit_08's Avatar
its looking good bro!!
Old Jun 7, 2009 | 03:21 AM
  #57
Thanks man
Old Jun 16, 2009 | 10:44 PM
  #58
It been awhile since I last update
A bit more sanding...
remade the box with....a little bit much?
fully dry....forgot to take pics of the round edge
-It's going to be fully fiberglass....Carbon Sheet goes way above my budget
Old Jun 19, 2009 | 12:25 AM
  #59
So I got 2x2 foot alum plate for fairly cheap, but the catch is that there this stupidly strong sticker on it.
started sanding with 60gits
about 30mins
1 hr
started on the 2nd one
about an 1hr in my class mate past me a can carburetor cleaner....takes just as long but the finish is nicer
AND LOOK WHAT WE GOT HERE
Old Jun 23, 2009 | 03:17 AM
  #60
the prep work before laying fiberglass, I used the 3oz. satin weave
started to mixed the resin, about 30mins it started to get too hot that it melted the cup...sorry didn't took pictures
4 Layers of the fiberglass and to the vacuum bag...hopefully it would look good.....
Sidenote, I GOT TO MAKE THE SCOOP AGIAN...stupid bondo
