Arometrics Air Freshener Ruined my Stereo Control Panel
Old May 13, 2009 | 05:17 AM
ke422azn's Avatar
The dealer says the control panel is directly connected to the radio and if I had to replace it, I would have to replace the whole thing which is 600 dollars. Does anyone know where I can get this for cheaper?
I had the air freshener where the center air vent is. It basically driped down vertically, crossed the display, and horizontally below the display.
FYI never buy arometrics air freshner, this piece of crap ruined my car.
Old May 13, 2009 | 05:47 AM
Koi's Avatar
Koi
It's the risk you run with any air freshener that has liquid that can spill out, not just Arometrics. Speaking of which, I better move mine away from the center so it can't drip over the electronics.
If you're looking for just the control unit (not the actual audio unit inside) - Bernardi Honda has it for $358.79 - part # 39100-TK6-305ZA
The audio unit is #39171-TK6-A01 and $416.64
Good luck.
Old May 13, 2009 | 10:12 AM
Speedmojo's Avatar
Same thing happened in my SRT-4. It ruined the stock radio screen along with the HVAC controls. I will never buy another airfreshener that contains organic solvents.
Personally when it comes to airfresheners I prefer the small pouches. They don't last long but you toss them under a seat and then replace every 2-3 weeks.
Another air freshener that I like are the vent tabs that insert into the vent. I haven't tried these on the Fit vents yet, but they work well and last longer than pouches.
Old Sep 7, 2009 | 10:31 AM
mjaccord's Avatar
Exclamation Liquid Air Fresheners are a hazardous material
About two weeks ago I had decided to buy an air freshener with a different appeal, so I went to the AutoZone and purchased the Arometrics air freshener. I wish I knew about the potential risk about this air freshener.
I placed the air freshener in the front vent above the stereo. The temperature here has stayed around the 80's. To my surprise, about a few days later I took the car for a drive. Immediatley, I could not believe what hap happened to my front panel. It looked as if someone had poured liquid acid and instantly peeled the material of the panel including the touch bottoms for the stereo device. I realized the problem was the ''Arometrics air freshener" after the battle was covered with liquid which had dripped on my front panel.
Avoid liquid air fresheners at all cost. I have used liquid airfresheners before but of different brands. Unfortunately, I didn't run with the same luck this time with "Arometrics".
bikerdrumr
Sep 13, 2019 12:19 PM
AdamButlerTV
Jul 29, 2015 06:06 PM
75r90rider
Sep 26, 2014 06:22 PM
Solscud007
Jul 15, 2013 04:36 PM
GTRPLYR
Jan 18, 2012 04:00 PM
