?uestion about CEL's
Old May 19, 2009 | 02:16 PM
DrKelso's Avatar
I went to autozone yesterday to get my CEL scanned to see what was wrong so I can fix it. When we plugged in and attempted to scan, we got "Operator Error! Please check connections..." and so on and so forth.
I remembered that my fiance's brother also has a OBDII scanner and so I asked to borrow his, and go the same message
My question is: Am I plugging the scanner into the right port? It makes sense to think that there would only be 1 port in the whole car that matches up to the connectors on the scanner.
The port I've been using is located just under the steering column, above/in front of the gas pedal.
Any info/insight/help is greatly appreciated. I'm getting tired of staring at that CEL all day.
Thanks
-Nick
Also, I have tried resetting the ECU by doing the whole battery disconnect/hold the brake pedal down thing.
Old May 19, 2009 | 02:56 PM
TekXoID's Avatar
Only time I've seen a random CEL is when I didn't tighten down the gas cap enough. Take it to the dealer, they usually scan it for free.
Old May 19, 2009 | 03:04 PM
DrKelso's Avatar
not my dealer They want $120 to scan it. Then they say that the $120 will apply to all repairs blah
Old May 19, 2009 | 03:14 PM
TekXoID's Avatar
Whaaaat. Is it out of warranty? If not then just take it in to service and play stupid "Uhhh this light just came on what the ****...?"
Find a better dealer.
Old May 19, 2009 | 03:43 PM
DrKelso's Avatar
^^ haha I wish I could get them to do it under warranty. Unfortunately, I've got enough mods that they could probably take their pick and blame it on that one
and as far as I've found....all chicagoland dealers (that I've checked so far) charge $110-$120 for the CEL scan
Old May 20, 2009 | 06:16 PM
DrKelso's Avatar
No one's had a CEL to scan yet?
Old May 29, 2009 | 01:42 PM
explosivpotato's Avatar
I've scanned my CEL 100's of times with my scangauge. I can't clear them with the SGII, though, for whatever reason, but I sure can read them. It sounds like there's something wrong with your CAN bus or OBDII port. Unless you've modified the electricals in your ECU harness I'd take it in to the dealer and tell them there's no way your mods have broken your OBDII system. What mods have you done?
Old May 29, 2009 | 02:09 PM
BlueCell's Avatar
that is the correct port. Sometimes I have the light on but no codes. So either your CEL is going on and off and the scanner cant read it or theres a bad connection somewhere. If you have Autozone in your area, they do it for free.
FUKNDUBN
Oct 25, 2011 11:18 AM
rookie33333
Aug 7, 2011 04:50 PM
FitVic
Apr 11, 2011 07:13 PM
Goodguy-Fly
Jun 15, 2009 12:32 AM
docjim2
Dec 28, 2006 05:06 AM
