View Poll Results: Which ETD are the best?
Spoon
30
61.22%
j's racing
16.33%
ingall
14.29%
weapon r
4.08%
other
4.08%
Voters: 49. You may not vote on this poll
Which Torque Damper are the best?
Old May 30, 2009 | 11:21 PM
Kurse's Avatar
Title said all, im looking to buy a engine torque damper, which one are the best? I've seen the spoon, j's racing, ingall, weapon r and more..
Help pls!
Thanks
Old May 31, 2009 | 12:46 AM
Contrabida Face's Avatar
i've been thinking about getting the ingalls etd, it looks sleek and not shiny. as for the best..... i've have no idea. they all get the job done, it's all on brand name preference.
Old May 31, 2009 | 08:15 AM
Kurse's Avatar
But if i install the spoon, i think i cant install a a strut bar in front.. look at this:
But i've see J's racing make one with a strut bar, but i dont like the bar cuz its not a solid one..
Old May 31, 2009 | 09:53 AM
amelsportfit's Avatar
yes you could install the strut bar....
Old May 31, 2009 | 10:19 AM
Kurse's Avatar
but if i dont want the spoon bar! im planning to buy the dc one piece
Old May 31, 2009 | 11:13 AM
im the fit's Avatar
My ingalls seems to rattle alot,and now the rubber inside feels alot softer than before, the good thing about ingalls are the bracket but there ugly it let's you use any strut,ide like to use a different damper with ingalls bracket.
Old May 31, 2009 | 12:38 PM
1990hondahf's Avatar
What about prices, who is the cheapest?
Old May 31, 2009 | 01:36 PM
kylerwho's Avatar
spoon fed
i would say get the spoon one because im a firm believer in that company.
j's has a front strut bar and etd combination package that you can consider.
personally i would just skip the etd and go right to harder engine mounts because the etd really destroy the stock engine mounts quickly because of the soft rubber in the oem mounts.
Old May 31, 2009 | 03:54 PM
Guinness's Avatar
I like J's Racing. Just look at Ben's AJR Timeattack GD and seehow much J's racing stuff is on it. =\
Old May 31, 2009 | 08:30 PM
Im|Inside|Fit's Avatar
Spoon ftw!!! =)
Old May 31, 2009 | 08:32 PM
kelsodeez's Avatar
UNBANABLE
engine mounts ftw!!!
Old May 31, 2009 | 10:38 PM
Spooling's Avatar
Innovative 95A engine mounts
Old Jun 1, 2009 | 03:25 AM
suketoborudo00's Avatar
for my Spoon ETD ,all 3 top mounting nuts loosened and fell off. the bolts are pretty long so they were still in position and the ETD was still semi-functioning.. replaced with some nuts from homedepot now I just check it monthly to make sure it doesn't loosen up again.
was going to recommend you try Ingalls because it's out of the way and would seem to have more stiffness, but hearing some weird stories about how the rubber washer melts off and other stuff like that i donno how serious a factor it is.
i still like the spoon etd, just wish the bolts would loosen so easily (had them really tight too). i think it's caused from downshifting for engine braking making lots of engine vibration.
Old Jun 1, 2009 | 03:53 AM
revd34's Avatar
i'm going agree with the other people on this thread and say get solid motor mounts. you wont need an ETD after you put them on.
if you do get one, get spoon. when you put the nuts in pull back the fender liner and put a nut on the other end of the bolts
Old Jun 1, 2009 | 12:36 PM
JDMxGE8's Avatar
Spoon Sports FTMFW!
Old Jun 1, 2009 | 10:37 PM
junktea1's Avatar
Do you know that the J's Racing and Spoon ETD are the same? They are both made by the same ETD co. in Japan. This same co. also makes ETDs for Silvias.
Old Jun 1, 2009 | 11:57 PM
dewthedew's Avatar
dont waste your money jsut get engine mounts
Old Jun 2, 2009 | 06:10 PM
los_creeper's Avatar
i too am in the market for a full suspension upgrade, wondering the same question myself...
i remember reading somewhere about the first spoon brackets breaking and reading somewhere else later on that they fixed it with a redesigned bracket?!
i also remember aj-racing had mounts for sale, but i don't see them on their site no more...
wasup? info? hmm...
Old Jun 3, 2009 | 09:04 PM
The Tech-1's Avatar
torque dampers suck, get upgraded mounts or even motor mount inserts are still better than any torque dampers.
ZiaMan
Nov 20, 2013 01:20 PM
jdmsneakerhead
Jun 25, 2010 01:57 AM
DrKelso
Dec 12, 2008 07:54 PM
Jonavin
Toronto Community
Feb 6, 2007 10:05 PM
