DIY: Installation of lowering springs on 07-08 GD3
Old Jun 11, 2009 | 07:50 PM
  #61
Fat Ping Cat's Avatar
i second that.. cutting the rear bump stop is not necessary
Old Jun 26, 2009 | 11:01 PM
  #62
Black01's Avatar
This needs a sticky
Old Jul 3, 2009 | 09:01 PM
  #63
FLFIT239's Avatar
ill be using this next week thanks
Old Jul 27, 2009 | 11:33 PM
  #64
dasboot's Avatar
I used this Saturday to install my Skunk2's. Thanks!
Old Jul 28, 2009 | 12:04 AM
  #65
chrisng's Avatar
i agree this really should be a sticky! it helpled me a lot!
Old Jul 31, 2009 | 08:04 AM
  #66
nc26's Avatar
can i use this diy tutorial for eibach pros?
and my car is a uk GD1
Old Jul 31, 2009 | 01:32 PM
  #67
Polish's Avatar
I got my Skunk2 springs in the mail today.
On my lunch break ( 1 hour ) I ran to the bank, post office box, taco bell then went home and had 40 mins left. I ate, had a cig, took a dump and had like 30 mins left. In that 30 mins (Of which 5 is needed to get back to work) I had the rear springs installed and the car ready to go. I was back to work with 1 min to spare.
Moral of story?
The rear spring install for this car couldn't be any easier.
I'll have the fronts done tonight when I get home.
Old Jul 31, 2009 | 01:35 PM
  #68
FLFIT239's Avatar
^sick guy
Old Jul 31, 2009 | 01:40 PM
  #69
Daemione's Avatar
This is me being anal, but you don't need a 3/4" socket, just stick with a 19mm so the whole job is metric.
Old Oct 17, 2009 | 03:39 PM
  #70
sbualuba's Avatar
Great DIY! But I'm having an issue, I noticed that when I turn the wheels the top of the strut moves a little. So do they need to be tighted more?
Old Oct 17, 2009 | 06:57 PM
  #71
sbualuba's Avatar
bump with this.. i need help before i can drive my fit!!!
Old Oct 20, 2009 | 03:35 PM
  #72
Tofuman's Avatar
^ Sounds like you may have missed a step or forgot to install a part. The strut tower should look like this if everything is reinstalled correctly.
and the shock assembly should look like this (well, with your aftermarket spring installed instead of this stock spring).
Old Oct 20, 2009 | 06:21 PM
  #73
sbualuba's Avatar
My fronts have the words up. I think this my be the issue, others have said the fronts should be upsidedown.
Old Oct 20, 2009 | 06:27 PM
  #74
Tofuman's Avatar
this is possible. i believe my fronts installed with the logo upside down. the upper spring clip seat (the light gray colored thing that you wind the spring into) should be on straight. it would look crooked if the spring is installed upside down.
Old Oct 20, 2009 | 07:44 PM
  #75
my springs had the text facing right side up. if i remember correctly they only fit one way, the rears are a different story
Old Oct 20, 2009 | 11:21 PM
  #76
sbualuba's Avatar
Well they sit in the light Gary peice fine. What I found is that the spring going over bumps moves out of the grove... When car is jacked up I can move the spring by hand. So first I though ok so the nut compressing the spring is not tight enough. So I used an impact on it and gained about five threads but, it sill moves inside it's bottom seat. It just won't stay in the grove. So I'm going to turn them upside down and see if that works, if it doesn't I give up. I had no extra parts... Any ideas?
Old Jan 2, 2010 | 07:30 AM
  #77
jazzista's Avatar
Hi all and have a great 2010!
I have a small question. I've just bought myself a couple of H&R springs and my local garage keeps on repeating the OEM shock (a Kayaba, I think) must be modified in order to avoid being destroyed. Now, I wonder if the front bumpstop trimming is simply all what's needed to have the springs correctly installed.
Thanks in advance and, again, best wishes of a great year!
Stefano
P.S.:Is there any way to add some more caster to original setting? I find the steer dull in getting realignment after a corner.
Old Jan 7, 2010 | 06:27 PM
  #78
Tofuman's Avatar
Stefano
The stock shock doesn't been to be modified. The bump stop does need to be cut though.
Also - you're probably looking for more negative camber, not caster. you'll probably want to get a camber bolt kit for the front after lowering the car anyway. SPC makes an affordable one.
Old Jan 8, 2010 | 04:46 AM
  #79
jazzista's Avatar
Thank you, Tofuman,
so the trimming would indeed suffice even if car is usually used moderately loaded?
About the caster/camber, I've read the caster is what helps wheel self centering and that's what I find lacking in SWMBO's Honda Jazz/Fit. Would you mind explaining me how negative camber might helps steering wheels getting self centered after a corner?
Meanwhile, I'll give a look at the SPC kit...
Thanks a lot,
Stefano
Old Jan 26, 2010 | 06:59 PM
  #80
Scala's Avatar
Great Right up! thanks
