hows this sound?
Old Jul 6, 2009 | 12:39 PM
GD3_Wagoon's Avatar
Originally Posted by FLFIT239
16x7 4x100 35mm offset 73.1 mm hub bore i dont know what that last part means but would this fit on my gd and what wheel would fit best?
that spec will rub but it's a small price to pay for how sick it'll look when the wheels are flush with your fenders
73.1 mm wheel bore is in reference to the diameter of the center bore of the rim -- IIRC the Fit's hub bore is 56.1mm. you're going to need a set of hub rings (hubcentric ring adapters) to help mount the wheels correctly; otherwise, you'll get wheel vibrations on the freeway and risk damaging the hub bearings.
EDIT
to minimize the rubbing i would get 195/45/16 tires and add a bit of camber, maybe -1.5 or -2. i rub on 15x7 +40 with 205/50/15 tires -- BUT i'm pretty low, tucking tire on the front and a little bit in the rear and i've only got -1.2 camber.
Last edited by GD3_Wagoon; Jul 6, 2009 at 01:11 PM. Reason: doh. bearings, not rings..
Old Jul 6, 2009 | 01:03 PM
FLFIT239's Avatar
yeah ive decided to just save money stick with the stockers and only get new tires
Old Jul 6, 2009 | 01:18 PM
GD3_Wagoon's Avatar
boo..
jk! good idea, the OEM dunlops are poo.
if you still want that flush look you might consider adding a spacer. 5mm in the front and 8mm in the rear should be enough. i put my sport wheels on my mom's eg with that same spacer width and it looks really good IMO.
Old Jul 6, 2009 | 01:36 PM
FLFIT239's Avatar
yeah dude they suck plus im not sure what i want i was thinkin konig remembers or work equip 03's but i just cant afford to spend that kinda money right now so new tires and some minor mods will have to do for now
Muster
Jun 24, 2011 06:02 PM
dewthedew
Dec 13, 2008 08:25 AM
racecarshots
Dec 5, 2008 04:47 PM
korky
Jun 4, 2008 03:33 AM
FITGD3
Jan 21, 2008 07:00 AM
