Worth the money to get a header and B-pipe?
Old Jul 19, 2009 | 08:01 PM
ride_the_pony69's Avatar
I currently have an Aspec axle back and am thinking about getting the mid section and also a header. Is it even worth the money to get a header and finish my exhaust? Will I get or feel any hp gains from that? I am going to be running an intake as well and no tuning. Thanks.
Old Jul 20, 2009 | 06:15 PM
FITGD3's Avatar
worth if you willing to spend $
Old Jul 20, 2009 | 06:16 PM
keepitpg's Avatar
i love college
i dont think a b-pipe is worth it, although it does make your exhaust sound alot better
Old Jul 20, 2009 | 08:36 PM
DynamicFit's Avatar
The header and intake will give you noticeable power gains, but I'd only go with the b-pipe also if you decide you want to go FI. Keeping the Factory B-pipe will also keep your exhaust from getting tooo loud.
Old Jul 21, 2009 | 07:02 PM
Ok cool, so don't waste my money on a b-pipe then. I do not plan on going FI. I am just adding a couple of bolt ons. I will be going with a short ram intake and I already have an Aspec axle back exhaust. So I should be good with just adding a header and I will get gains from it? Thanks.
Old Jul 22, 2009 | 02:45 PM
i donno. ive modded many NA's in the past and the performance gains are only marginal... (you gain noise).
if i were you, i would invest more money on the suspension and wheels/tires.
Old Aug 5, 2009 | 12:00 AM
DOHCtor's Avatar
A Header like a DC Sports or T1R will give you more midrange for sure because of the sightly bigger pipes and '' A LOT'' better collector!! A race Header like the Weapon R Race will give more top end power!!
If you have an AT go DC or T1R... MTX, it depends of your goals!!
As of the B-Pipe, like the others allready said, it's unlikely to give big gains on a Fit with only a couple of bolt-ons!!
If i were you, i would put an a Air Intake (Fujita, AEM, Injen!), then a Header and then a Pulley... Polishing the lower plenum maybe will net you some power and it's almost free if you have a dremel and some skills!!
Marko!!
Old Aug 5, 2009 | 12:11 AM
LaoSiFu's Avatar
+1 the increase (if there is an increase) of power you get is so little. I would only consider a full bolt on if you are going FI. If not then I would do strictly suspension work.
~Robert
Old Aug 5, 2009 | 07:38 PM
leonine's Avatar
Dont waste your money on performance mods for the fit unless your ultimate goal is to boost it. Not worth it otherwise.
Old Aug 6, 2009 | 05:08 AM
kodo's Avatar
get a blitz throttle controller and try SP3 mode you will never go back, it won't add HP but will make the car more fun to drive.
Old Aug 6, 2009 | 02:12 PM
Gbaby2089's Avatar
^don't get those........they're garbage IMO and in the opinion of one of the top dudes at cosworth......just get some c/o's and sticky tires you'll love your car
BigTuna_GD3
Nov 26, 2010 11:43 PM
setter11
May 4, 2009 01:43 PM
drzenitram
Jul 7, 2008 01:32 PM
explosivpotato
Jul 3, 2007 08:35 PM
TomiGunz
Feb 1, 2007 10:00 PM
