How to fix stripped screwhole for cargo cover button?
Old Jul 27, 2009 | 07:34 AM
drevil's Avatar
Yesterday I was installing the button/screws for my 2009 cargo cover's front flap, and I muscled it a little too hard and stripped the predrilled hole in the back of the seat. Has anyone ever done this also or know how to fix it? Thanks!
Old Jul 27, 2009 | 12:53 PM
Btrthnezr3's Avatar
Hmm...I'm not sure but I'm thinking...you know those like "inserts" you put into the wall before you screw something really heavy duty in?
Maybe one of those would work...I'm gonna see if I can find pics...
Apparently they are called "drywall anchors"
They have all different sizes/types...I have a few in my toolbox...it may be enough to fill the hole and still let your screw go in...
Super heavy duty...
Should be able to find them at hardware store or walmart.
Old Jul 27, 2009 | 03:06 PM
gimme's Avatar
Master FitFreaker
put a toothpick in the hole, break it off then screw in the screw
because it is a machine thread, you maw want to split the toothpick down the center
Old Jul 31, 2009 | 07:44 PM
iujock's Avatar
I did this exact same thing and first tried loctite which didn't work and than I used super glue and so far it has held up.
Old Sep 25, 2009 | 11:12 PM
calrose rice's Avatar
I guess if the screw bit is stripped and you want to remove it off the seat, you could just use a pair of pliers and grab and twist. Short term repair, but still works.
Old Sep 26, 2009 | 07:35 PM
i removed that flap thing completely on my GE. it gets into the way 99% of the time anyway.
Old Sep 26, 2009 | 08:47 PM
Btrthnezr3's Avatar
Ken--is there a big gap now? Any chance you could take a picture?
Old Sep 26, 2009 | 09:15 PM
Perrenoud Fit's Avatar
Okay you got that hole wallered out so much the screw will not tighten down, so if the screw is standard self threading type all ya gotta to do is fill the hole with hot glue. Be very careful and put a towl under the spot your fillin in cuz what ever it comes in contact with it stays in contact with!! this stuff is very pliable after it's squwirtted were it's needed. Give it a few minutes to cool down and put the screw back in. Any hobby store or Sears will have a hot glue gun and there great for other projects also.
Gimme's idea is a good one too, and Quick
Yao Moua
Aug 15, 2017 09:55 PM
2Fit2
Jun 3, 2011 10:05 PM
RaXeT
Feb 11, 2011 12:22 PM
turanuk
May 28, 2010 12:47 AM
jenhonski
Jan 1, 2009 11:20 PM
