View Single Post
  #151 (permalink)
Old 08-06-2009, 11:32 AM
lugies's Avatar
lugies lugies is offline
lugies relies on Rep Points to livelugies relies on Rep Points to livelugies relies on Rep Points to livelugies relies on Rep Points to livelugies relies on Rep Points to livelugies relies on Rep Points to livelugies relies on Rep Points to livelugies relies on Rep Points to livelugies relies on Rep Points to livelugies relies on Rep Points to livelugies relies on Rep Points to live
Quote:
Originally Posted by dsmwookie View Post
It has been mentioned several times, why are their no specifications on the coil resistance?
Why replace any parts if they are not the right one? Just because you put a new coil doesn't mean it fixed the problem just possibly masked it. Your coils can be tested one at a time and if they are within range they are not the problem. More often than not they are going bad from mileage and weather changes have a large affect on resistance.
So who has a shop manual with the specs so we can accurately test this problem rather than speculate?
Koolkev please no more advice your just swapping parts and guessing.
If I knew how to do that and had any idea how then I would have. Nevertheless, the changing the coil packs stoped the shuttering. I just took it on a trip from Arkansas to New York and back and didn't have a single problem. I even got good gas mileage again, up to 40 mpg at times
