Swap: L13A to L15A - possible?
Old Jun 30, 2009 | 10:26 PM
Type 100's Avatar
Originally Posted by GTornado
Well, I've done some research here and Honda is only offering the L13A engine for the new Fit. So, there seems to be no other way than importing an engine. I am not sure, but the GE L15A does have some differences to the GD engine, doesn't it?
I already mentioned the slightly different intake design, but this is shared among all GEs. I know the intake manifold itself is also shaped a little differently.
The main difference is the i-VTEC head on the GE L13A and L15A. The GD L15A's VTEC is basically a valve-idling mechanism...below 3500 RPM the engine uses only one intake valve per cylinder. The i-VTEC head adjusts timing and lift across the whole range.
2009 Honda Fit Sport - Honda Tuning Magazine
Other differences would probably involve the wiring as Jazz it up! has stated.
Temple of VTEC Asia has detailed technical write-ups on the GE L-series engines if you're curious.
Honda L-Series SOHC i-VTEC Engines for the new GD Honda Fit/Jazz
More power in stock form is always good
Old Jul 6, 2009 | 10:43 AM
isitafox's Avatar
I was looking into the swap as I've got a UK 1.4 SE Sport which is the L13 i-dsi. I came very close to getting an engine but money let me down, as far as I know it should be a straight swap over in terms of tranny fitment and engine mounts and if you're running an auto box you just need an ecu from an auto l15. Not sure bout the left hand drive side of things but I can't see it being that much of a problem as they don't make 2 seperate engines for different hand drive cars. Any garage should be able to advise you on that. Hope that helps!
Old Aug 8, 2009 | 10:16 AM
santa's Avatar
Hi pal,
I'm driving the same L13A twin spark engine as you and looking into getting more juice out of my ride legally.
Surprise a swap is legal compare to boast. anyway, heard that a GE is not compatible with our GD engine. not aware how true is the statement.
However you may wanna consider a GD L15A Vtec?? some work required dou.
Before swap, have u consider doing up your engine? since you are not after that maximum gains from FI.
cheers,
Santa
Old Apr 23, 2010 | 06:50 PM
mgutt's Avatar
Any updates regarding swapping L13A to L15A? Is it possible? Any DIYs online?
Old Jun 16, 2010 | 09:22 AM
Happy__Fit's Avatar
yeah any uodates ?
Old Jun 16, 2010 | 03:56 PM
mgutt's Avatar
I've bought a JDM GD3. It arrives in the next 6-8 weeks.
Images:
http://www.maxrev.de/jdm-jazz-gd3-t151955.htm
crash001
Jul 29, 2011 05:37 AM
trinisir
22
Aug 29, 2009 08:23 PM
Bukwheat
Sep 25, 2008 07:02 PM
blackice
Sep 17, 2007 07:25 PM
azkikersfit
16
Apr 27, 2007 12:54 AM
