Honda Civic Alternator Light
Old May 4, 2005 | 11:16 AM
ssampage
Guest
Posts: n/a
Hey there. I have a 95 Civic with a relatively new battery. Yesterday
I gave my friend a jump start...did everything by the book, etc. A few
hours later while driving, my alternator light started coming on. It
flickered for a while, then stayed on, then stayed off, then came back
on again. I've started the car several times over the past two days
and it's cranked right up every time. I haven't noticed any dimming of
lights or anything else that would indicate electrical drain either.
So did I screw something up or is the light just a coincidence?
Remco
Guest
Posts: n/a
Re: Honda Civic Alternator Light
It could also be that, while you jump started the other car, you
jiggled your power connections to the battery where they may be
intermittent now -- clean them with a battery post cleaning tool (cheap
at any autoparts store) and tighten them well.
Perhaps check to make sure that the voltage across the battery is 14V
or more with the car running.
TeGGer®
Guest
Posts: n/a
"ssampage" <ssampage@netscape.net> wrote in
news:1108420100.689115.128010@o13g2000cwo.googlegr oups.com:
Worn alternator brushes!
You can get a brush holder assembly for about $25 from the dealer and
install it yourself.
TeGGeR®
www.tegger.com/hondafaq/
speedy
Guest
Posts: n/a
....but you can get the brushes for about $2 from an auto electric supply!
-SP
TeGGer®
Guest
Posts: n/a
speedy <seedy@raex.com> wrote in news:111atrataq80g3b@corp.supernews.com:
True, but then you've got to solder them into the holder after removing the
old brushes.
TeGGeR®
lister
Mar 8, 2020 12:58 PM
crunchie
Jan 31, 2019 03:31 PM
Tymd
Mar 16, 2017 08:24 AM
Rocky
Oct 15, 2005 03:30 PM
Remco
May 4, 2005 11:16 AM
