GD3 Rear Diffuser....Custom Fabrication
Old Aug 12, 2009 | 12:58 PM
spooned's Avatar
Talking GD3 Rear Diffuser....Custom Fabrication
***CURRENTLY ON HOLD TILL I FIGURE OUT A NEW WAY OF MOUNTING (cardboard is becoming my new friend)***
I recently bought a Nighthawk Black GD3 and I was under it today thinking about creating a rear diffuser for it since I haven't seen one yet. It will run from the center of the car to the rear. So it will incorporate almost a full rear under try as well.
As of now, I just want to gauge some interest in who would like one of these if I decide to go through with making more of these once I've completed mine.
Construction will be out of sheet metal for now and possibly out of carbon once I have my template completed.
Let me know what you think!
Old Aug 12, 2009 | 12:59 PM
spooned's Avatar
Reserved for build pictures/info
First...don't make fun of my MS Paint skills
So...my plan is to go from the bolts in the front to the rear lip clips. Yes, I know, connecting this to the clips on the rear lip isn't a very strong anchor, but...the diffuser isn't going to be pulling down on the rear, its made to channel the air smoothly under the car. It will not be pulling down or pushing up on the rear. Once completed, there will be no need to make additional holes for bolts. Everything will be compatible with OEM bolt holes.
"Rough" mockup of the first panel minus the fins...haven't gotten to tat quite yet. This is with the stock bolts. Final product will have bolts that sit more flush. Hopefully accompanied by some finishing washers if I can find the right size. Final product may also be shorter then what i'd like due to the difficulty of bolting the tray to the 4 bolts toward the front of the car highlighted in the above picture. if someone wants a full length tray drilling would be required to mount.
Old Aug 12, 2009 | 01:16 PM
dewthedew's Avatar
interested!
Old Aug 12, 2009 | 02:28 PM
goodyonsen's Avatar
sounds goood
Old Aug 12, 2009 | 05:09 PM
Fit Happens's Avatar
Subscribed!
Old Aug 12, 2009 | 07:09 PM
spooned's Avatar
so i ran into some complications today. I wanted it to be 65" x 24" but its just not going to work. I went all out trying to bend and connect the diffuser to the bolts toward the front of the car like I originally planned but it just didn't work out. So i'm deciding to shorten it up to 48" and run some bracing down the top of it to stiffen it up a little. I also has to trim the sides down to 20" instead of 24" due to exhaust clearance.
The heat pushed me back inside today since it was about 110 degrees outside today and my garage was no different. I'll start working on it tomorrow morning to see what I can get done before I have to go to work.
I just wanted to add that I'll most likely rivit the panels together to make them a little more sterdy
Old Aug 13, 2009 | 01:08 PM
spooned's Avatar
I've come to realize that this little project is a complete failure. I found out for myself why no company has made a diffuser for the fit yet....and that is because there is a huge lack of mounting areas in the rear of the car causing too much flimsiness in the material. So this project is going to sit in my garage for a little bit until i find a solution.
Old Aug 13, 2009 | 01:24 PM
FitFlowjoe's Avatar
Boo!!! I was excited !!
Old Aug 13, 2009 | 01:28 PM
spooned's Avatar
I was too but everything is so limiting underneath. I'll try to figure something out. Make it out of cardboard first. Cheaper trial and error haha
Old Aug 14, 2009 | 12:02 PM
redrumm's Avatar
Old Aug 14, 2009 | 12:40 PM
dewthedew's Avatar
Hmm Ill have to bring some cardboard home from work and see what i can come up with.
Old Aug 14, 2009 | 05:04 PM
spooned's Avatar
Originally Posted by redrumm
who makes this...i was looking on that cleanmpg.com page but couldn't find where you got the picture
Old Aug 14, 2009 | 05:32 PM
dewthedew's Avatar
I think that's the spoon under tray for the s2k
Old Aug 14, 2009 | 05:36 PM
spooned's Avatar
I'm almost positive that password jdm is the only company to produce a full undertray for the s2000. I have a s2 and have looked into this before
Old Aug 14, 2009 | 08:43 PM
Lol, that's a Mugen underpanel for our little Fit!! Or actually it's for their Fit Dynamite concept, so it wouldn't quite fit our bumpers!
Old Aug 14, 2009 | 10:09 PM
redrumm's Avatar
it was posted up on honda tech. i just pulled the pic
Old Aug 14, 2009 | 10:16 PM
If anyone wants a "source" to the pic http://www.mugen-power.com/concept/dynamite/index.html
and then click on "spec"
Old Aug 15, 2009 | 12:41 AM
spooned's Avatar
^^that Fit is awesome....if only they were released over here. I'd definitely pick it up
Old Aug 16, 2009 | 03:09 PM
DrKelso's Avatar
Will this be compatible with the Progress RSB that many of us have? I don't think it would be an issue...but I feel it's worth bringing up.
.:Edit:.
nevermind...just saw that this has been abandoned for the time being
Maybe I'll make a go at it haha. I've been needing an excuse to learn to weld
Old Aug 16, 2009 | 03:17 PM
spooned's Avatar
Once I actually figure out some mounting points i'll look into the swaybar question. I highly doubt that there would be a problem since I'm thinking the best way to create this with my limited amount of sheet metal tools will be to shorten it up a little and possibly wider. Only problem with going wide it the many different exhaust variations and their size and mounting. I'll keep everyone updated. I'm currently trying to find a local shop to get some bending done at.
