coilover question . .
Old Sep 8, 2009 | 06:43 AM
jazz_do_it's Avatar
I heard from a mechanic that each time you lower your car, you need an alignment . .
Does this rule also apply if you have coilovers?
I don't know much about coilovers so i posted this, kindly help me.
Thank you. .
Old Sep 8, 2009 | 08:13 AM
CuTeBoi's Avatar
Is the car lowered with the coil overs?
Old Sep 8, 2009 | 08:26 AM
jazz_do_it's Avatar
not yet, i am planning to buy one . .
I am currently on H&R springs . .
Old Sep 8, 2009 | 08:46 AM
Daemione's Avatar
Yup. Any time you change ride height, or change just about anything on the suspension, you need an alignment.
Old Sep 8, 2009 | 09:00 AM
jazz_do_it's Avatar
so if i buy a coilover, i need to get an alignment each time i adjust the ride height?
Thank you very much . .
Old Sep 8, 2009 | 09:37 AM
CuTeBoi's Avatar
you answered your own question. If you change ride height, you "should" realign for that height...
You answered your question in the OP
Old Sep 8, 2009 | 09:54 AM
YellowStarS2000's Avatar
Just FYI, when you lower the car your toe is changed. This is the single most vital spec that causes premature / uneven tirewear.
Old Sep 8, 2009 | 10:48 AM
jazz_do_it's Avatar
when i got my lowering spring installed, i did not get an alignment.
I got it aligned after a couple of months when i noticed uneven wear, can that cause any damage to my suspension?
Old Sep 8, 2009 | 05:32 PM
DatFIT's Avatar
No... but lowers the lifetime of your tires.
FITSOCIETY808
Jul 6, 2011 05:50 PM
danger69
Jan 21, 2010 12:48 AM
CrystalFiveMT
Feb 5, 2009 07:59 AM
AWDturbo
Nov 4, 2008 03:02 AM
jsensk
15
Feb 22, 2008 09:59 AM
