Noise coming from rear brake drum (right side)
Old Sep 29, 2009 | 09:37 AM
.eL's Avatar
.eL
I'm not sure how this started but I did notice it immediately after rotating my wheels.
The problem is this cyclic noise coming from my rear right brake drum. It's an obvious metal contacting metal sound in a cyclic occurrence. It happens all the time, while braking or accelerating.
I took off my drum to do a visual inspection and didnt notice anything and when I put everything back together, the sound was gone.
A day later though, I'm hearing the sound again and it's either just as bad or worse than before. The pads looked fine to me and I didnt notice anything abnormal so I'm completely baffled by this.
Any ideas?
Old May 16, 2010 | 06:31 PM
glen62's Avatar
clicking noise at brake action
.el,
Did you solve the clicking noise at these time, I get the same cliking ramdomly, each time I press the brake pedal, any cleared idea at this time, I know has passed a long time since you posted
Old May 16, 2010 | 08:44 PM
.eL's Avatar
.eL
The problem just went away on it's own for me after a while.
Maybe you should inspect your brakes closer to see if anything's wrong.
Old May 18, 2010 | 02:50 PM
vag0's Avatar
Originally Posted by glen62
.el,
I get the same problem clicking when coming to a complete stop
Old Jun 25, 2010 | 01:41 PM
blue line's Avatar
there may several reasons for rear drum brake noise-
Most common on new cars, particualry, after a wheel removal is bent dust cover
second is brake wear (shoe/Drum
third isbrake self-adjuster
fourth- trapped dirt
BunnyHopper1981
May 17, 2017 09:17 AM
Piyo2005
Aug 21, 2012 05:25 PM
msoulier
Jul 22, 2011 11:22 AM
OEMfit
Dec 27, 2008 06:38 PM
bittermelon
Mar 27, 2008 03:46 AM
