Console Install
Old Oct 4, 2009 | 07:38 AM
polokid69's Avatar
Console Install
Below are some pics of my new console, while this one is an inexpensive one, it was easy to install and will do for now until I can afford the factory one.
Here it is before install, two pieces total
Bottom half
bottom piece view from front
underside of bottom half
side view of top half
top view of upper half
underside of top piece
upper piece extended
whole unit hinged in up position
first remove the arm rest
align after joining both pieces and screw down to console
Attach to rear of lower console
finished product
Trying to figure out how these detach if anyone has an idea ?
This console was only $60 shipped bought on Ebay UK so not bad a starter
New License Frame:
Old Oct 4, 2009 | 08:19 AM
55Fit55's Avatar
To remove those old armrest bolts, just get a metric open-end wrench on it back at the base, where the bolt meets the seat.
I forget the wrench size.................maybe 12mm or somewhere around there.
Old Oct 4, 2009 | 01:14 PM
polokid69's Avatar
Thanks, that did the trick. Couldn't get a 12 on them, used a 9/16 but at any rate both came out. Do they make a plug or something for that armrest hole ?
Old Oct 4, 2009 | 02:05 PM
55Fit55's Avatar
My console from zetaproducts came with a plug. You could check their site to see if they sell them individually.
Old Oct 4, 2009 | 03:26 PM
jnesselroad's Avatar
how do you like this armrest? what's the quality like? i was just about to order one, glad to see a pic installed finally. what's the height in comparison to the factory driver's side? looks about the same. thanks!!
Old Oct 4, 2009 | 04:30 PM
polokid69's Avatar
I just installed last night so haven't been out to test yet but I'll keep you posted. As for the height, I'm not sure how high the other ones are by comparison but I guess I could measure from top to roof. As far as the quality, I'm a little dissapointed. I had a simular one on my 08 Fit and it was much more sturdy. This one is securely attached but feels weak compared to my old Fit's console. It is nice in that you can swivel up out of the way but lack much storage room although my goal was a better armrest. Overall, for the $65 I paid for it including shipping, it's probably worth that much and is better than the old armrest attached to the seat.
Hope that helps, feel free to ask other questions you have about it.
Old Oct 4, 2009 | 04:39 PM
polokid69's Avatar
Just an FYI, the Zeta one look like the one from my old FIT and it was very sturdy.
Old Oct 4, 2009 | 06:13 PM
polokid69's Avatar
Ok, just took a drive and tested the new armrest. First, only one person can rest their arm on it at a time. Next, it has some left to right flex movement going on. Overall, if you want an inexpensive console it's bearable but I really would not recommend it.
Old Oct 7, 2009 | 05:36 PM
WhiteSnake's Avatar
I bought one just like it and it did not come with the drivers seat cap. I think it will still install with the OEM armrest still attached on the drivers seat, just a guess. I plan on just using the OEM one and won't be installing the new one. Anyone wants it, I'll sell it for $45 shipped. PM me if interested.
Update: It won't instal unless the driver's seat armrest is removed. However, it would be something that the Base Fit could use as there is no driver's seat arm rest (if memory serves me).
Old Oct 7, 2009 | 11:15 PM
fmcfad01's Avatar
I installed the Honda Accessory armrest. It's perfect and worth the money. It also looks a hell of a lot better than the one pictured here (or any other one people have posted thus far). I have a base fit. If anyone wants the cap to cover up the armrest you have to remove, I'll be glad to send it out. The base didn't have an arm rest on the side of the seat, so I'll just throw it out otherwise.
shawnthemonster
Nov 6, 2010 12:37 PM
jeiarneesi
Mar 25, 2009 07:08 PM
Raaaaaaaaaay.
Mar 20, 2009 03:29 PM
jeffquach
Dec 1, 2008 11:37 PM
Raaaaaaaaaay.
Sep 1, 2008 08:24 PM
