Wheel spacer question...
Old Oct 12, 2009 | 10:35 AM
mugenfit79's Avatar
Hey guys... I have a set of 16X7 40 offset rims on my 2007 Fit Sport. I lowered it with Tanabe GF210 springs. I want to add wheel spacers to give my ride a little more aggressiveness. What MM spacers do you guys recommend? I want go wider in the back than the front. Thanks!
Old Oct 12, 2009 | 03:50 PM
Jodele's Avatar
Suspension Geometry
NONE… you will just make a bad situation worse!
The Honda Accessory Wheel is a 16 X 6-1/2 with a 55-mm offset. Take a look at the picture and you will see that the suspension geometry goes through the center of the contact patch.
When you installed the 16 X 7 with 40-mm offset, the wheel is wider and cannot go in because of the MacPherson strut. With the centerline of the strut already 5/16-inch inboard of the centerline of the tire, your handeling is probably already marginal.
If you add wheel spacers, you will completely FUBAR the suspension!
Adam_Melton
111
Apr 16, 2023 10:12 PM
Mooser1454
Sep 25, 2018 05:01 AM
liverpoolfcfan
Mar 29, 2012 08:01 PM
mugenfit79
Feb 15, 2010 05:32 PM
m-man@sbcglobal.net
Oct 28, 2008 01:56 AM
